cooldude:
Why not go for passive speakers all-over.
Works great with the av7000, as it already has the build-in amp for the center channel.
For the front L/R channels , I use a powerlink cable to a MCL2p amp unit. (you'll find plenty of these on ebay, fairly cheap) connecting any passive speakers with 2pin din plugs.
Same for the back L/R channels.
I have 5 pcs CX100 speakers as my home theater right now and works well for me.
I use the cona sub as my subwoofer, connected to my front speakers.
Mixing beolab (powered speakers) with beovox (passive speakers) does not seem to mix very well. If you put powered speakers in the back, they'll be too powerful for the setup.
The beo4 will work ok for everyday use, but I suggest the good 'ol bl1000 remote, which is available on ebay for under $100.
Hope this info works for you.
Sorry, "cooldude", been away for a few days. Much obliged for the
information and insights on the the A/V 7000. If I manage to find a
clean one, I'll be back to you for more enlightenment! I have only book #
1 which my son gave me and it only shows what can be done with it using
the Beolink 1000, not how it works, but I've seen digisnaps of the back
with all the DIN and RCA connections.
I'd figured the "color"
(sound) might pose a conflict between active and passive but was hoping
someone might tell me otherwise...
You are running 5 x CX100s
off the 45W from the A/V 7000 for the center channel and 2 MCL2ps = 4 x
30W? Isn't that a little anemic? Please explain. (My son had also
suggested CX100 for the rear with my M70s up front. )
Made the
mistake of speaking to the "local" B&O dealer, 125 miles from here.
He advocated an "upgrade" to BeoLabs 3s and a Beolab 11 for
starters! THAT would require selling a few of my remaining toys to
finance I can tell you! Might go and listen with my son anyway. Will be a
hard sell as my M70s sound very good still with my "new" Beomaster 7000
and CD7000 and my freshly serviced old 4002. Maybe I'll see what all
the fuss is about with this acoustic lens business. At least he didn't try to sell me Beolab 9s!
First a clean A/V 7000 and we'll see where this leads.
for the help!
Note: Besides the 5.1 coming from my HDTV cable
box, my musical tastes are fairly ecletic, mainly Baroque and Romantic,
with a challenging mix of vocal, choral, harpsichord, organ, and some
jazz but zero "pop". In my book, it has to sound live, the way it does
in the hall, with no "processing" or "enhancement". That's what B&O
used to be all about. Hope that's still the case.
