Latest post 04-19-2010 3:11 PM by stotty1111. 4 replies.
Page 1 of 1 (5 items)
  • 04-16-2010 12:05 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BS4 and input from a beogram(with riaa amp)
    Hi all
    Not been a good day bnowise(see other posting) - got a bs4 which I am wanting to play vinyl through and also possibly record to sd card - all set up, rca input into in sockets, tried a-aux on beo4, shift /radio bl1000 --  nothing!
    Anyone out there point me in the right direction    --  have check the handbook think I'm doing everything as directed
    HELP!!
    cheers
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 04-16-2010 5:04 PM In reply to
    Re: BS4 and input from a beogram(with riaa amp)
    I assume that you are using some form of DIN to RCA adapter. If so, is it the correct one to pick up the correct pins in the DIN?
    Regards Graham
  • 04-17-2010 3:14 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    graham
    the din had been removed, and rca's fitted as the dck was used with a mission amp - i assume the leads are fine however will make up an rca to din piece and use it with the bc9300 to check - have also had this problem getting a sony deck to work as well - lying in the pit last night struck me it might be in the option selection as the sony unit worked thro' the bs brfore i linked it to the mx7000 - hey ho lifes never easy/simple!
    let you know later off exhibitting myself today (model boats etc)
    cheers
    t
  • 04-17-2010 5:22 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Did you set A-AUX in BC4 menu settings / options to "ON" ?
  • 04-19-2010 3:11 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi guys
    Tried that Vienna still don't work - made up the rca to din 7 (audio link), tried the bg with the bc9300 works a treat - so problem is in the bs4 me thinks - I'll try resetting the beast to factory settings and start from there - maybe the unit software is somehow compromised!
    Watch this space!
    Re the model show over the weekend, some poor sole was killed by a runaway model plane saturday afternoon - couldn't believe it a poxy hick show so to speak and some family loses a loved one!
    salut
    t
