Latest post 04-15-2010 1:49 PM by joeyboygolf. 7 replies.
Page 1 of 1 (8 items)
  • 04-15-2010 5:35 AM
    • DanB
    • Not Ranked
    • Joined on 04-15-2010
    • Posts 4
    Beosound 3200 broken down
    My Beosound 3200 has seized up and will not even switch on.  The green light is on but the doors do not open and, if I open them manually, none of the buttons work.  There was no event which would have cause this - not dropped or excessive temperatures.  I took it to my local b&o store and they said the computer has broken and will cost 300 to 400 to replace.  It is only 5 years old.  Has anything similar happened to your 3200 and if so how was it resolved?  Any suggestions for how to resolve?  Thanks in advance.
  • 04-15-2010 6:41 AM In reply to
    Re: Beosound 3200 broken down
    Take it to another dealer. The "computer has broken" is not a sensible reason to give.
    You have not helped yourself either!
    We don't know where you are so "it will cost 300 to 400 to replace" does not mean a lot. Is that UK Pounds, Danish Kroner, US dollars or Yen or what???
    Regards Graham
  • 04-15-2010 6:42 AM In reply to
    • DanB
    • Not Ranked
    • Posts 4
    UK Pounds
  • 04-15-2010 7:28 AM In reply to
    That sounds like a lot of money.
    Was this response as a result of a quotation from their service department or just a "salesmans bluff" to get you to replace the 3200?
    If it were mine, I would pay for a report from qualified service people. It may cost an hour labour time but at least it should be accurate and will give you a much better idea of what will need to be replaced and the likely cost. You can then make a decision and give us a better idea.
    Regards Graham
  • 04-15-2010 8:34 AM In reply to
    • DanB
    • Not Ranked
    • Posts 4
    Not sure - I had to chase after dropping off the unit a week before and the salesman said an engineer was in later and would call back.  They called back with this vague price later - (inc VAT, labour?).  No mention of an upgrade so unlikely to be part of a salesmans bluff.  Do you know where I get access to a qualified service person?
  • 04-15-2010 8:41 AM In reply to
    Through the dealer if they have an in house department or yellow pages if they use a third party contractor.
    Where are you?
    Regards Graham
  • 04-15-2010 9:10 AM In reply to
    • DanB
    • Not Ranked
    • Posts 4
    Near Manchester UK.  Think I will pick the unit up and try a different store.
  • 04-15-2010 1:49 PM In reply to
    Try
    Unit 4 55 King Street
    Manchester
    Lancashire
    M2 4LQ
    United Kingdom
    Tel: 0161-8326159
    Fax:
    They are members of this forum
    Regards Graham
