Hello,
I've now got a superb Beocord 2200, in as-new condition. I think it was never really used. The woodwork looks new too, which is rare. Everything is shiny, no dust whatsoever, even the power cord looks new!
It works fine too. It sounds great, as Tim Jarman said in Hi-Fi World last month. Azimuth is set perfectly, and no wow or flutter. Impressive. [edit: wow is indeed audible after recording].
Happy? No, because at first it didn't power up. On close inspection, I discovered a tiny V shaped spring in the case, which belongs to the power switch. After hours trying to put it back in, I gave up. It is impossible! I can see exactly where it goes, but because of the spring stiffness I'm unable to put it in its place (which is obvious).
Edit: I finally managed to put it back, but the spring won't hold in place (I guess some plastic thingy broke inside), I will have to find a replacement switch. Also, when I record from my BM 6000 the input saturates (the rec pots are below 1 for 0dB). But there's no treble loss.
Any ideas please? Would anyone here have the part?
Jacques
