On blocket.se I found this ad:
http://www.blocket.se/landskrona/Hittegods_Mobiltelefoner__Klockor__Smycken__K_26869024.htm?ca=23_8&w=3
It´s a box from a lost and found compartment. It´s all or nothing, so if you want the B&O you´ll get som cell pones as well. The current bid is 1 500 SEK, about 150€.
The question is, how the heck can you loose that B&O. If it had been a Serene or a BS2 or 6 I could understand it.
