Diggs,
Page 14, See two sources simultaneously, of the BeoSystem 1 User Guide explains a little.
Picture-in-Picture
When Picture-in-Picture is switched on and a TV or Satellite source is shown in the small window on the screen, you can change
channels for that source. If VCR is selected in the window, then you can play, cue or wind the cassette.
While e.g. TV is on...
LIST Press LIST repeatedly until P-IN-P
P-IN-P appears in the Beo4 display
SAT Select which source to display in
VTAPE the small window*
DVD
Operate this source with Beo4 as usual
0 Press to swap the sources
To move the inserted picture...
Use the coloured buttons to move the picture to one of the corners of the screen
TV To exit the P-IN-P function, press the source button that corresponds to the source shown in the main picture
*NOTE! Do not choose the VCR as your Picture-in-Picture source if a recording is being executed on your VCR, as Picture-in-Picture may
disrupt your recording. BeoSystem 1 will attempt to avoid the situation by making it impossible to activate the Picture-in-Picture function.
BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
