Latest post 04-13-2010 6:30 AM by auclutch. 3 replies.
Page 1 of 1 (4 items)
  • 04-12-2010 9:57 PM
    Beosound 3 Power Adaptor (Ampere Question)
    so my daughter recently managed to completely destroy the power adaptor for the beosound 3.  long story short, I have to buy a new one now.  The local B&O dealer is asking KRW 200,000 (roughly USD 200) which I think is highway robbery given that a local electronics shop sells a similar one for USD 15.  The problem is that the original is 15V 1A and the one at the local shop is 15V 1.5A.  I tried plugging it in and it has no problems charging the battery and playing.
    My question is will using the 1.5A vs. 1A adaptor damage the beosound 3 or it's battery?  I defer to the beoworlder's expert advice.~
    BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
    2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
  • 04-13-2010 5:29 AM In reply to
    Re: Beosound 3 Power Adaptor (Ampere Question)
    Should work well. The main difference is that the one at the local shop can deliver a higher amperage than you actually need.
  • 04-13-2010 6:15 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Harry2008:
    Agree with that, as the battery charges up the amount of amperage going in will taper off anyway.
    CraigSmile
  • 04-13-2010 6:30 AM In reply to
    thanks guys, you just saved me a trip downtown and 200 bucks.  where should I send the beers?
