Latest post 05-26-2010 12:55 PM by wouter_yvo. 5 replies.
Page 1 of 1 (6 items)
  • 04-10-2010 6:38 AM
    Oppo BDP-83 XML needed
    Hallo
    Can some one help me with the XML file for Oppo BDP-83 Smile
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
    Filed under:
  • 05-23-2010 2:49 AM In reply to
    Re: Oppo BDP-83 XML needed
    Hi Tillquist,
    I managed to make one. You can download it here: http://dl.dropbox.com/u/1479282/Oppo%20BD-83%20SE.xml
    Please let me know if it worked for you!!!
    Best regards,
    Wouter
    Filed under: , ,
  • 05-24-2010 4:09 AM In reply to
    Wouter,
    A Warm Welcome to your first posting and thank you for your link.
    I noticed that this unit uses 32 bit NEC protocol which as your file uses RAW (Image copy) it may not work correctly with "Repeat" such as fast forward. So, I have taken your codes and converted them to use pure NEC codes and I have also pre-assigned teh number and other hard keys.
    You can download the new XML file HERE and I would be pleased to receive feedback on how well it works.
    Regards Keith....
  • 05-24-2010 5:22 AM In reply to
    Keith,
    Thank you for checking the XML for the Oppo BD-83. It works perfectly!!! I have also made an XML file for my Rotel AV-receiver (RSX-1560). I would appreciate it if you could check that one also (if it's not too much trouble)... You can find it here HERE
    Best regards,
    Wouter
  • 05-24-2010 6:32 AM In reply to
    Wouter,
    Your Rotel AV-receiver (RSX-1560) has a device code of HEX 83
    It also uses 32 bit NEC protocol and you can download the XML file HERE for test
    Regards Keith....
  • 05-26-2010 12:55 PM In reply to
    Keith,
    Sorry you had to wait for my response. The xml for the Rotel works just fine! Thanks for that.
    Regards,
    Wouter
