Latest post 04-10-2010 5:46 AM by jp2010. 8 replies.
Page 1 of 1 (9 items)
  • 04-08-2010 7:03 AM
    • jp2010
    • Not Ranked
    • Joined on 03-08-2010
    • Posts 7
    Converting Pronto Codes for use with Beo5
    I have now had my Beo5 for about a month and thanks to this forum I already managed to configure it to 95% of my requirements.
    Now I would like to add 3rd-party support for my EyeTV decoder (product website) which can be controlled using the Elgato Remote. I have found a Pronto .ccf file at remotecentral.com and managed to extract the Pronto codes using ProntoEdit. Here is an example for digit 1:
    0000 006d 0022 0002 0155 00ac 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 0040 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0040 0015 0040 0016 003f 0016 0040 0015 0040 0016 003f 0016 0648 0155 0056 0016 0e51
    And for digit 2:
    0000 006d 0022 0002 0155 00ac 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 0040 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0040 0015 0040 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 003f 0016 0648 0155 0056 0016 0e51
    This is where I struggle. When I try to convert these codes using the Lintronic CodeLearner, the convert button is greyed out (I do not own their hardware). Is there any other way of converting the Pronto Codes to Beo5 codes, which I could then use as inputs for Keith's XML Generator?
    Any hints would be highly appreciated.
    Thanks and kind regards,
    JP
  • 04-08-2010 8:39 AM In reply to
    Re: Converting Pronto Codes for use with Beo5
    A Warm Welcome to your first posting.
    Your two HEX Pronto codes decode to NEC protocol using a carrier frequency of 38Khz and a product device address of 45
    1 has a command code 0f Hex 03 and 2 has a command code of Hex 04
    The following is a conversion into an XML format accepted by the Beo5 Configuration tool:-
    <?xml version="1.0" encoding="utf-8"?>
    <root stVersion="1.3">
      <resource>
        <image stName="NonBO" stFile="Images\NonBO.bmp" />
      </resource>
      <product stName="test" stCaption="test" stImage="NonBO" stProductType="accessories3Party" stAV="AV1" stAV1OUT="SCART" stScreenType="1">
        <source_item stName="test" stCaption="test" stShortPressCommand="test" stScreenType="0" stMenuCaption="test" stSourceType="accessories3Party" stIR="" nPreferedRow="4" nPriority="1" nPreferedColumn="1" nPage="1" nX="0" nY="95" nWidth="213" nHeight="25" nRowFinal="4" nColumnFinal="0">
          <source_subItem stName="2" stCaption="2" stMenuCaption="2" stScreenType="0" stIR="NEC:GlobalManual=1#IRSEQUENCE=NEC#BITS=010111010101110111011111001000001#ALTBIT=#MARKFLANK=560#SPACEFLANK=560#SPACE2FLANK=1680#PRESIGNALHI=9000#PRESIGNALLO=4500#Pause1=65000#Pause2=65000#Carrier=38#REPEATSIGNAL=0#Comment=NEC 32bits+Delay: 50ms+NEC:GlobalManual=1#IRSEQUENCE=NEC#BITS=1#ALTBIT=1#MARKFLANK=560#SPACEFLANK=560#SPACE2FLANK=0#PRESIGNALHI=9000#PRESIGNALLO=2250#Pause1=30000#Pause2=30000#Carrier=38#REPEATSIGNAL=1#Comment=NEC 1 bit" stLeave="Rel 1" stIRVideoOp1="1" stIRVideoOp2="1" stIRVideoOp4="1" stIRVideoOp5="1" stIRVideoOp6="1" stIRAudioOp1="1" stIRAudioOp2="1" stIRAudioOp4="1" stIRAudioOp5="1" stIRAudioOp6="1" stIRVideoOp2Av="1" stIRVideoOp4Av="1" stIRVideoOp6Av="1" nPage="1" nX="213" nY="20" nWidth="213" nHeight="25" nRowFinal="1" nColumnFinal="1" stTextColor="255:255:255" nHidden="0" />
          <source_subItem stName="1" stCaption="1" stMenuCaption="1" stScreenType="0" stIR="NEC:GlobalManual=1#IRSEQUENCE=NEC#BITS=010111010101110100111111110000001#ALTBIT=#MARKFLANK=560#SPACEFLANK=560#SPACE2FLANK=1680#PRESIGNALHI=9000#PRESIGNALLO=4500#Pause1=65000#Pause2=65000#Carrier=38#REPEATSIGNAL=0#Comment=NEC 32bits+Delay: 50ms+NEC:GlobalManual=1#IRSEQUENCE=NEC#BITS=1#ALTBIT=1#MARKFLANK=560#SPACEFLANK=560#SPACE2FLANK=0#PRESIGNALHI=9000#PRESIGNALLO=2250#Pause1=30000#Pause2=30000#Carrier=38#REPEATSIGNAL=1#Comment=NEC 1 bit" stLeave="Rel 1" stIRVideoOp1="1" stIRVideoOp2="1" stIRVideoOp4="1" stIRVideoOp5="1" stIRVideoOp6="1" stIRAudioOp1="1" stIRAudioOp2="1" stIRAudioOp4="1" stIRAudioOp5="1" stIRAudioOp6="1" stIRVideoOp2Av="1" stIRVideoOp4Av="1" stIRVideoOp6Av="1" nPage="1" nX="0" nY="20" nWidth="213" nHeight="25" nRowFinal="1" nColumnFinal="0" stTextColor="255:255:255" nHidden="0" />
        </source_item>
      </product>
    </root>
    Regards Keith....
  • 04-08-2010 4:46 PM In reply to
    Please also see here for an older version of the Lintronic tool that works.
    Cheers,
    Frank
  • 04-08-2010 5:28 PM In reply to
    • jp2010
    • Not Ranked
    • Posts 7
    Keith and Frank,
    thanks very much for your warm welcome and quick response. I already found the link to the older version of Lintronic last night in the forum, however, I do not understand how to reproduce your results for my Pronto codes above. Looking at Keith's XML code, the main difference between the two commands is found in
    How do I calculate these bit streams from my Hex codes using Lintronic? Apologies if the answer is too obvious, but I am really stuck here.
    Also, I noticed a difference in nColumnFinal which is set to "1" for digit 1 and "0" for digit "2". Is this difference intended and if so, what does it mean and where do I read it from Lintronic. I have about 12 commands to convert and would like to avoid bothering you with that any further.
    Many thanks,
    JP
  • 04-09-2010 5:47 AM In reply to
    The binary 32 bit strings contain in 8 bit blocks the device address, then the inverted and reversed device address, then the command, then the inverted and reversed command.
    You said:-
    How do I calculate these bit streams from Hex codes using Lintronics
    My Comments:-
    The XML Generator only converts Lintronics timings to RAW format meaning it is an IMAGE copy only which is fine for static commands such as off and on. However, for protocols such as NEC about 50% of devices will ignore the REPEAT function, i.e. "Fast Forward" The Beo5 firmware has the NEC protocol implemented in the firmware which requires the binary string provided.
    As you have all your commands available in Pronto HEX format, I suggest you post them and I will convert them for you to a fully functioning XML file.
    You also said:-
    My Comments:-
    It certainly was intended. These are the positions of "1" and "2" on the screen. If you have the screen default of 4 x 3 meaning 4 rows and three columns, the columns are numbered from 0 to 2. If the number was the same, then both numbers would be on top of each other.
    Regards Keith....
  • 04-09-2010 6:59 AM In reply to
    • jp2010
    • Not Ranked
    • Posts 7
    Keith,
    Thanks much for your reply and your generous offer to convert my Pronto codes. I have listed them below. Would be great to have those converted to a Beo5 xml file.
    Thanks a lot and kind regards,
    JP
    "Digit 0"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e50
    "Digit 1"
    "Digit 2"
    "Digit 3"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0040 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Digit 4"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0040 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e50
    "Digit 5"
    0000 006d 0022 0002 0155 00ac 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0040 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0040 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 003f 0016 0648 0155 0055 0016 0e51
    "Digit 6"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0040 0016 0040 0015 0040 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Digit 7"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0040 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0040 0015 0040 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Digit 8"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0040 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Digit 9"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e50
    "Select"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0040 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0015 0015 0040 0016 0647 0156 0055 0016 0e51
    "Back"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0040 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0040 0016 0015 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Enter"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 003f 0016 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Title"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 0040 0016 0040 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0040 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "OK"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0040 0016 0040 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0040 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Up"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0040 0015 0040 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Down"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 003f 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0015 0016 0040 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Left"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0040 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Right"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 003f 0016 0015 0016 0040 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Red"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Green"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0040 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0015 0016 0040 0015 0040 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Yellow"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0040 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Blue"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e50
    "Play/Pause"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0040 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 003f 0016 0040 0015 0015 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Skip back"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0015 0016 0015 0016 003f 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 003f 0016 0040 0015 0015 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Skip forward"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0040 0016 0015 0016 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0040 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Rewind"
    0000 006f 0022 0002 0015 01e4 0013 0041 0011 001a 000c 0048 0012 0018 000c 001e 000c 001e 000c 0049 0012 0018 000e 0047 0013 0016 000f 0046 0014 0016 0010 001a 000f 001b 000f 0045 0015 0015 0013 0041 0016 003e 0016 0014 0015 003f 0016 003f 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003e 0016 0015 0016 0015 0015 003f 0016 003e 0016 003f 0015 062b 0156 0054 0015 0e0f
    "Fastforward"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "Mute"
    0000 006d 0022 0002 0156 00ab 0016 0040 0015 0015 0016 0040 0015 0015 0016 0015 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 0015 0015 0040 0016 0015 0015 0015 0016 0015 0016 0015 0015 0015 0016 0015 0016 003f 0016 0015 0016 003f 0016 0040 0015 0040 0016 003f 0016 0040 0015 0040 0016 0647 0156 0055 0016 0e51
    "FS"
    0000 0070 0033 0000 0007 019a 000b 16e1 002f 01c7 0015 003e 0016 0014 0015 003f 0016 0014 0015 0015 0016 0014 0016 003e 0016 0014 0016 003e 0016 0014 0016 003e 0016 0015 0016 0014 0015 0015 0016 003f 0015 0015 0016 003e 0015 0015 0016 0014 0016 0015 0015 0015 0016 0015 0016 003e 0016 0015 0016 0014 0015 003f 0016 003e 0016 003f 0015 003e 0016 003e 0016 0015 0016 003e 0016 061d 0072 0007 0001 0773 0016 0def 0003 019e 0002 0e03 0006 019b 0005 0e00 0005 019c 0005 0e00 0155 0053 0016 0def 0155 0053 0016 0def 0155 0053 0016 019a
  • 04-09-2010 9:46 AM In reply to
    • jp2010
    • Not Ranked
    • Posts 7
    Keith Saunders:
    Keith, could you explain why the 32bit codes actually have 33 digits? Is the 33rd bit a check-bit and if so, is it the one at the end or at the beginning?
    I have just done some further testing and based on the two codes provided by you, the 2nd and 4th 8-bit-sequences are simply inversions (but not reversals) of the 1st and 3rd 8-bit sets. Con you confirm this?
    Sorry about all these quite technical questions. I am trying to figure out the composition of these codes to use more than one set of Apple remote control command sets with my Beo5 and Remote Buddy on my Mac. This way, I can assign 12 or 18 commands, i.e. 6 from the original command set provided with the Beo5 Config Tool, and then another 6 commands with a slightly changed device address, as Remote Buddy distinguishes betwen remotes with different IDs.
    Thanks a lot for your help so far. Kind regards, JP
  • 04-10-2010 2:37 AM In reply to
    You can download the produced XML file HERE
    Extract the zip file to C:\ and the XML file will be placed into the correct directory in the configuration Tool.
    All digits are pre-assigned to the numbers screen.
    All commands not in the screen have been assigned to hard keys
    Command FS is not a NEC protocol command and was converted to RAW and may not be a valid command.
    Regards Keith....
  • 04-10-2010 5:46 AM In reply to
    • jp2010
    • Not Ranked
    • Posts 7
    Keith,
    Many thanks for your support on converting those Pronto codes. I really appreciate it.
    I also did some more testing and found a very good solution that might be interesting for other people with similar setups.
    I have a BV8-26 connected to a Macbook Pro via HDMI. I have also got some BL3s connected to the BV. I am using Plex as a mediacenter for movies and music and EyeTV as TV tuner and recorder. I was looking for a seemless solution to control EyeTV and Plex using my Beo5.
    On the Mac, I run Remote Buddy. As RB distinguishes between Apple Remotes with different IDs, you can actually assign those physical Apple Remotes to logical remotes in RB. I found 3 different Apple Remote comand sets on the web, which gives me 18 distinct commands. You can assign those commands to whatever you want in Remote Budddy. I wrote a few Applescripts that allow me to switch between EyeTV and Plex and some other specific tasks. The end result is a setup that seemlessly integrates EyeTV and Plex without the need to navigate through Remote Buddy's on-screen-display
    The real advantage is that you actually do not need an external IR receiver. There are 256 different Apple Remote IDs, which gives you 1536 distinct commands that can be recived by your Mac's internal receiver and put to use in Remote Buddy.
    If this is of interest to anyone else, I am more than happy to share my Beo5 and Remote Buddy configuration. Also, If anybody has caputred the IR codes of their own physical Apple Remote, it would be great to share those to increase the number of distinct commands available. I have the command sets for IDs 33, 122 and 167.
    Regards,
    JP
