Hello again. I am only just now getting round to doing this job. I have looked at a number of other car speakers such as JVC and Pioneer but the sizes vary. Because I know that you have used these successfully in your Beomaster I am inclined to go for the Visaton speakers which can be sourced in UK for £32.50 per pair. Can you confirm whether, because of the depth of the speaker surround, did you have to fix the new ones to the rear of the cabinet rather than the front as the originals were fitted?
From the same supplier there is also a Visaton FR9.15 speaker which is cheaper and slimmer but has a power rating of 15w as opposed to 30w for the speakers you used. Do you find the power rating of your DX 4x6 P an ideal match for the Beomaster?
