I would not like to use a Gefen device. I think I can use Component connection as well. This would then be DTV on my Beo4.
Additionally I could try to connect Audio OUT of ATV to A.Aux of my BS3200.Or could I connect directly to BV8 as Audio device?
Do you think this could work?
As I learned now, the BEO4 can do everything the Apple Remote can do. The Beo5 can learn additional commands with ATV. Which would that be (please give me some examples.)
Do you have any experiences with ATVflash to increase AppleTV functionality??
Thanks a lot.
Heribert
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
