Latest post 04-03-2010 1:41 PM by schaibo. 2 replies.
Page 1 of 1 (3 items)
  • 04-02-2010 6:54 PM
    • schaibo
    • Not Ranked
    • Joined on 06-25-2007
    • germany
    • Posts 15
    Beomaster 6500 FM receiver
    I noticed that I suddenly get nothing but static on my preset stations. I don't really listen to the radio a lot so it's not that big a deal. Anyway, is this an "easy" repair or more complicated?
    Filed under:
  • 04-03-2010 3:50 AM In reply to
    Re: Beomaster 6500 FM receiver
    That's not a easy  job, you need some experience and at least a frequency counter and a oszilloscope.
    Or you are lucky: look for bad solderings, especially around the wire connectors. Check the heat of the chips.
    Try to set a known frequency with the MCP, notice the answer to the MCP, what frequeny is displayed.
  • 04-03-2010 1:41 PM In reply to
    • schaibo
    • Not Ranked
    • germany
    • Posts 15
    I was even luckier :) – when I opened the beomaster to check the solderings as you suggested I found that the only problem was a very loose, grey cable. Works like a charme again.
    Thanks for your quick help!
