Latest post 06-22-2007 3:00 AM by beologisch. 10 replies.
Page 1 of 1 (11 items)
  • 06-21-2007 6:24 AM
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Witch one of Beosound 3000 and beosound 4 have best sound quality?
    Witch one of Beosound 3000 and beosound 4 have best sound quality? Does anyone no if  beosound 3000 or beosound 4 have burrbrown D/A converter?
     And the only diffirence i can se is that beosound 3000 have masterlink instead of powerlik on the beosound 4.. When do i have an advatege of masterlink? only if i want to play in muliroom ore what?
    Regards Fredrik L
    BL8000 MkII Black
  • 06-21-2007 6:33 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: Witch one of Beosound 3000 and beosound 4 have best sound quality?
    They both have PowerLink and MasterLink...
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 06-21-2007 6:36 AM In reply to
    Hi Fredrik,
     both have masterlink and powerlink. powerlink is for connecting active speakers directly to the beosound and masterlink is for connecting the beosound with an B&O TV in one room (e.g. to realize a surround setup) and/or for connecting additional rooms.
    Marcus
  • 06-21-2007 6:48 AM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    The FM radio in the BeoSound 4 seems better, and there also seems to be a change in the sound of the CD player, although I may be imagining things!  Confused
    Both, as said have MasterLink and PowerLink. PowerLink is for connecting speakers, and MasterLink is for sending music around the house into different rooms.
    One advantage the BeoSound 4 has in terms of MasterLink over the BeoSound 3000 is the ability to play two things at once. For example, in the main room, you could be listening to CD through the speakers, and then in a different room, you could be listening to the radio.
    Also, the BeoSound 4 has DAB radio as well as FM radio, and an SD card slot for recording from CD/DAB/FM radio and playing back MP3s from your computer. The BeoSound 3000 has none of these.
     Weekly top artists:
  • 06-21-2007 7:38 AM In reply to
    • Beolab
    • Sweden
    • Posts 535
    So the better chois is the besound 4 then?
    BL8000 MkII Black
  • 06-21-2007 7:59 AM In reply to
    • Christian
    • Posts 626
    Beolab:
    Yes the BS4 has slightly better specs.
    If, however, you prefer the BS3000 designwise, then I would take the BS3000.
  • 06-21-2007 8:02 AM In reply to
    The way to put a CD into the BS 3000 is much easier than to put the cd into the BS 4, I find it a little bit clumsy. Designwise I prefer the BS 3000. But the BS 4 has the ability to play tracks from a memory card, the BS 3000 doesn't have this feature.
    Just because it's mellow it doesn't mean it's less evil....
  • 06-21-2007 10:30 AM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    I think there is no difference concerning the sound output between the two systems. The main differences are about handling and design, and about the radio, as Alex pointed out.
    There is a difference in sound quality between the BS9000 and the BS4/BS3000.
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 06-21-2007 8:05 PM In reply to
    • Beolab
    • Sweden
    • Posts 535
    I´m thinking that the BS3000 is a design ikon but old now, so the new BS4 is much more 2007 but a little to much plastc.. How much better is the sound from BS9000 then?
     According to the specs they are the same?? Do the have burrbrown DAC or ?
     Frequency range 20 - 20,000 Hz, +/- 1 dB
    Signal-to-noise ratio Typical 101 dB, A weighted
    D/A convertinig Bitstream, Analogue filtration
    Frequency range20 - 20,000 Hz, +/- 1 dB
    Signal-to-noise ratioTypical 101 dB, A weighted
    D/A convertinigBitstream, Analogue filtration
    BL8000 MkII Black
  • 06-22-2007 1:52 AM In reply to
    I personally don't believe any of the modern B&O cd players sound any worse than any other and certainly not a reason to not buy any of them. If there are technical differences they are not obvious in the sound produced through any of the B&O speakers that I have ever had.
    It has to be said that your chosen speakers have an enormous effect on the quality of the sound and any differences in the cd players pales into insignificance.
    Regards Graham
  • 06-22-2007 3:00 AM In reply to
    Beolab:
    It's all a matter of taste I suppose........... the BS4 design is far more modern looking than the BS3000 design, technically I assume the technique is more up to date as well, the BS3000 is more common looking and the BS4 looks strikingly beautifull in any room.
    Designwise I prefer the BS4, despite the rather odd way of sticking the CD between the glass door and the machine through a too narrow opening [if the door would open a bit further, it would make life a bit easier] the use of a memory-card is also a big plus.
    The sound-difference between the two depends on your speakers I guess, they are really the ones which will produce the sound [quality]
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
