Latest post 07-17-2010 4:06 PM by Eugene. 9 replies.
Page 1 of 1 (10 items)
  • 03-28-2010 11:58 AM
    • krisb
    • Not Ranked
    • Joined on 01-29-2008
    • Athens, Georgia, USA
    • Posts 28
    Beogram 5005 problems...
    Hi guys,
    I've got an annoying problem wit my Beogram and wondered if anyone else had ever experience his?
    It's started turning itself and my Beomaster 5500 off about 4 minutes into a record.
    It used to do this if it hadn't been used in a few weeks (if I was off on holiday etc) but would return to normal after a bit of persistent record playing...
    Maybe it's just a sign that Ive been busy and haven't been turning it on enough...
    Also does anyone know of of a good B&O repair shop in the US? Preferably i the south east?
    Kris
  • 03-28-2010 2:31 PM In reply to
    Re: Beogram 5005 problems...
    Hey Kris!
    I was wondering what happened to you! Always nice to find someone near me!
    I'm the fellow that gave you the BC5000 about 2 years ago...
    Someone will prob be along to help soon w/ the BG.
    RE: Service... You are in luck! You are about an hour away from B&o's regional service specialist.
    Modular Electronics in Roswell, GA. Ask for Benny, highly recommended!
    • B&o bottle opener
  • 03-30-2010 3:24 PM In reply to
    • krisb
    • Not Ranked
    • Posts 28
    Awesome! Thanks for that!
    And thanks again for that BC5000. It worked out great! It was eventually replaced with a BC5500. I still have it though, just not in use at the moment!
    Think I might actually finally check out the B&O shop in Atlanta this weekend! Not that can afford any of the newer stuff!
    Thanks!
    Kris
  • 04-01-2010 11:41 AM In reply to
    • krisb
    • Not Ranked
    • Posts 28
    Actually it seems that it's my Beomaster... it's been turning off even when I use my ipod...
  • 04-01-2010 11:55 AM In reply to
    Does it get unusually hot? Most probably this is the classic problem of the idle current setup trimpots being shot. They do that with old age, then the power amp eats too much current, and the protection circuits shut the Beomaster down before there's a change of more damage.
    If this is the cause, it is a relatively easy and quick fix with cheap spare parts for someone who knows what he's doing. Should be no problem for the guy Jeff already recommended Smile
    -mika
  • 04-21-2010 11:32 AM In reply to
    • krisb
    • Not Ranked
    • Posts 28
    Oh, I hadn't noticed whether it got hot or not...
    maybe that's it. I 'll take it to that guy this month to see if he can fix.
    Thanks for all of your help guys.
    Kris
  • 04-29-2010 11:56 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    You may have the sticky piston problem - I've seen that a few times in these caused sudden shutoffs.
    The piston needs to be rebuilt.
    This is a problem common to the whole range of the Type 59xx turntables.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 06-09-2010 2:41 PM In reply to
    • krisb
    • Not Ranked
    • Posts 28
    Great! Thanks for that, I'll pass along your advice and a print out of the pdf to the technician!
  • 07-16-2010 9:46 AM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    burantek:
    Hey Kris!
    Just emailed Benny about my cartridge.  He offers MMCx rebuilds.  Have not stumbled upon anyone having used this service, only Axel's in Germany.  Has anyone used Benny to repair an MMC4?
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 07-17-2010 4:06 PM In reply to
    Thanks for that little bit of info. I have an MMC4 that is in need of repair. May inquire next week.
