Latest post 03-28-2010 11:27 AM by Vienna. 5 replies.
Page 1 of 1 (6 items)
  • 03-28-2010 6:33 AM
    • Dennis
    • Top 500 Contributor
    • Joined on 02-01-2009
    • Denmark
    • Posts 172
    • Gold Member
    Are they Powerlink MK3 cables, or not?
    Hi Beoworlders!
    Yesterday I found an ad with a Beolab 3000 amplifier. The amplifier was connected to a Beovision or a Beosystem, and there was light in the display. But the cables didn't look like Powerlink MK2 cables, which I have been told, is the only cable that works with Beolab 3000! The cable on the picture, looks like a Powerlink MK3 cable for me! Can anyone tell me if the cable on the picture is a Powerlink MK3. I don't think that it is a Powerlink MK3 cable, because then the display won't work? But take a look at the 4 pictures:
    Regards Loudspeaker
    I was borned with a Beolink 1000 in my hand!
    Ever seen a Beomaster 6001? I have one! Look here.
    Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
    Wish list: Beolab 2,
  • 03-28-2010 7:47 AM In reply to
    Re: Are they Powerlink MK3 cables, or not?
    Your cables are thick and they carry the display info, so they are MK2.
  • 03-28-2010 9:33 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    Hi Phil!
    Thank you for your help :)
    I am about to buy cables for my own Beolab 3000's, so i hope you can tell me if the cables on the two pictures are MK2 cables (It is two different cables).
    Regards Loudspeaker
  • 03-28-2010 10:40 AM In reply to
    The bottom ones look thinner -> MK3...
  • 03-28-2010 10:45 AM In reply to
    • Dennis
    • Denmark
    • Posts 172
    • Gold Member
    Okay, thanks again for your help.
    Regards Loudspeaker
  • 03-28-2010 11:27 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    PowerLink Cables - fully mounted (all pins connected):
    Can be used for ALL Bang & Olufsen Speakers.
    The original PowerLink Cable (fully mounted) used for Pentas and BeoLab 3000/4500/5000 in the 80's & 90's had a diameter of 7mm.
    It was replaced by Powerlink Mk II with a diameter of 3,5mm.
    !! Recently Powerlink Mk II has been replaced by a NEW TYPE called "PowerLink Shielded" - a fully mounted and double shielded cable with a diameter of 5,5mm and available up to 50m !!
    A new Power Link Junction Box - B&O PartNr 3132055 is also available.
    PowerLink Cables - witout diplay data:
    Powerlink "thin" (diameter of 2,5mm) came with Beolab 4000/6000/8000 in the 90's *)
    It has been replaced by Powerlink Mk III (diameter 2,6mm) and factory made cables are marked with an arrow/ a triangle on the plugs. Custom-made Mk3 cables can be recognised by having an additional blue wire connected to pin 7
    *) avoid this cable ... it does NOT work with recent speakers like BLB2 /3 / 5/ 9 / BLB 4000UP ...
