Latest post 03-28-2010 10:51 AM by ducha. 2 replies.
Page 1 of 1 (3 items)
  • 03-27-2010 11:17 PM
    • ducha
    • Not Ranked
    • Joined on 01-04-2008
    • Wisconsin, US
    • Posts 77
    Remote Mains Switch
    Hello all,
    I have a Remote Mains Switch that I am contemplating using with my Beosystem 6500. I am considering adding an equalizer to the system. Can the remote switch be used to activate an equalizer? If so, where on the Beosystem 6500 would the device get connected?
    Thanks,
    Aaron
  • 03-28-2010 5:12 AM In reply to
    Re: Remote Mains Switch
    Yes, you could use this. To attach an equaliser, if you want one, you remove the blanking plug on the Beomaster 6500 and use a 5 pin DIN to 4 RCA lead.
  • 03-28-2010 10:51 AM In reply to
    • ducha
    • Not Ranked
    • Wisconsin, US
    • Posts 77
    Great, thanks for the reply Peter!
