Hi Guys
A software update was done to the beosystem3, everything seemed to be working fine, or so we thought, we can watch everything on bvis 4-65 no problem, however when we try the cinema mode nothing happens, I presume it has lost the settings, does anyone have rough idea what the settings should be I know each one is different but if someone can give me a rough idea I can figure it out from there. The other issue i have is Beosound 5, works fine in cinema room but, installed Beovision 8-40, being fed from beosystem 3 via composite then into aerial system, pict and control are fine but no sound, if i try av pc, i get the sound but it is distorted, on main home cinema it is fine, hope somebody can help
Kai
