Latest post 04-02-2010 1:39 PM by ligth011. 8 replies.
Page 1 of 1 (9 items)
  • 03-26-2010 8:45 AM
    Beolink Mobiel.
    Is dit het einde van de Beo4 en Beo5?Hmm
    Voor mij in ieder geval niet; wij gebruiken Serenes en kunnen de touch-functie van deze MLG niet gebruiken.Confused
    A new BeoLink application
    BeoLink is a new software application that can be used to expand and extend the Bang & Olufsen experience offered via the Master Link Gateway. It gives access to both AV and home automation systems using selected smart mobile phones with integrated Wi-Fi.
    It is specifically aimed at customers buying into the concept of the ‘intelligent home’. With the intelligent BeoLink application offered via App Store, Bang & Olufsen is able to provide a highly personalised and tailor-made Wi-Fi control via the mobile phone (or iPod Touch).
    Bang & Olufsen is among the very first companies in the world to introduce mobile control of both your AV equipment and your home automation setup in one solution.
    The application is downloaded to the mobile phone and replicates the setup of the scenes that the customer requested when installing the Master Link Gateway. The customer gets access to the selected scenes/zones from the mobile phone. It is a unique way to extend the benefits of the Master Link Gateway with control from the minute you are within Wi-Fi range.
    Benefits
    BeoLink is a Wi-Fi-enabled application that offers a
    Bang & Olufsen touch and feel to selected touch-sensitive mobile phones. It gives mobile phone users extra convenience and a sensation of magic-like control of both home automation and audio/video equipment at the touch of only one button.
    The graphical user interface (GUI) is extremely simple and well organised and designed to match what you expect from a touch phone. The source buttons can be moved around to your preference.
    BeoLink is not replacing the remote control you have in your home, but should be regarded as an extension and supplement that allows you to be in control even before you enter your home, after you have left your home, when you’re in the garden or simply whenever you have your mobile phone in your hand. It is simple, personal and convenient and a great solution for those who use the mobile phone extensively and prefer collecting all applications here.
    Communicating Master Link Gateway
    BeoLink is a unique opportunity to communicate the benefits of the BeoLink system and Master Link Gateway to a large group of existing and potential customers at the same time. It enables your mobile phone but does not replace your remote control. It offers control beyond the house limits. It is conveniently always at hand when you need it, and it is a highly personal tool.
    When would BeoLink be useful?
    You can see examples of different needs in different situations below
    On-the move context
    You are approaching home and want the gates to open • and the lights switched on (you are outside your residence and have Wi-Fi access).
    You are leaving home and want to switch off the music, • the lights and lock the doors (you are in your car leaving).
    Room context
    You are coming home entering your living room and • want to listen to the news – you access the room/zone and get control of what’s available in that room (context aware).
    You are on the phone and want to turn down the • volume (BeoLink provides the most used commands such as volume, track, channel, station etc. only).
    You are at home but still working and have not settled • in one room yet (your phone is closest to you).
    House context
    You cannot find the remote – but you always have the • mobile in my pocket.
    You want to turn on the music from the garden – the • remote is in the house.
    You want to open the garage door and turn on the • lights – your remote is in the living room.
    Only the most basic and generally most used remote control functions are implemented in BeoLink. Therefore, and by no means, is the mobile phone meant to be a Beo4 or Beo5 substitute.
    Programming
    The customer downloads BeoLink from the App Store free of charge and the installer or retailer simply synchronises it with the Master Link Gateway in less than 10 minutes. In the Master Link Gateway system, the retailer simply ticks off the feature and it automatically configures itself ensuring the same graphical user experience Bang & Olufsen has designed for the Master Link Gateway in the house. The synchronisation can be done via remote access (if enabled on the Gateway) or at the customer’s home via Wi-Fi.
    The BeoLink application will be rolled out in touch phones starting with iPhone and iPod Touch and followd by other touch phones later.
    Customers
    The target group for BeoLink is customers buying into almost any type of intelligent home, involving Bang & Olufsen AV solutions and our Master Link Gateway, but at the same time are looking for simplicity, elegance and convenience. Even the simplest installations will benefit from the BeoLink application.
    BeoLink will be upgraded with new functionalities as they become available.
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
  • 03-26-2010 9:48 AM In reply to
    Re: Beolink Mobiel.
    beologisch:
    Kennelijk niet.
    beologisch:
    Dat is best wel posh!
  • 03-26-2010 2:46 PM In reply to
    Re: Beolink Mobiel.
    ik heb al een jaar de MLGW in gebruik.
    Ik kan idd via mijn iphone de muziek licht,bronnen etc bedienen.
    nu schijnt er er app uit te zijn voor de iphone.(via webbrowser)
    Die heb ik nog niet gevonden op het net.
  • 03-31-2010 4:17 AM In reply to
    • beoblok
    • Top 500 Contributor
    • Joined on 03-19-2008
    • Finland
    • Posts 80
    Re: Beolink Mobiel.
    Kijk voor de Iphone App link
    Maurice
  • 03-31-2010 5:36 AM In reply to
    • Ericvr6
    • Joined on 04-17-2007
    • The Netherlands
    • Posts 205
    Re: Beolink Mobiel.
    mijn serene begint nu echt zijn beste tijd gehad te hebben dus wordt het een Iphone met deze app wel erg aantrekkelijk
  • 04-01-2010 5:24 AM In reply to
    • Ericvr6
    • The Netherlands
    • Posts 205
    Re: Beolink Mobiel.
    heb vandaag de knop door gehakt en de I-phone besteld
  • 04-01-2010 3:10 PM In reply to
    Re: Beolink Mobiel.
    ik heb de app erop staan maar zit de mlgw niet.
    vinkje staat voor enable mlgw.
    weet iemand iets?
  • 04-02-2010 4:04 AM In reply to
    • 8000
    • Not Ranked
    • Joined on 02-27-2010
    • Posts 50
    Re: Beolink Mobiel.
    Wat kun je allemaal met deze applicatie? Hetzelfde als wat ik met de Beo 5 kan? Of zijn dit maar beperkte commando's ?
  • 04-02-2010 1:39 PM In reply to
    Re: Beolink Mobiel.
    als je de app download kun je dat zien er zit nl een demo op.
    volgens mij meer als met de beo 5.
    zit ergaaf uit, alleen bij mij ziet de app de mlgw nog niet.
