Latest post 03-27-2010 1:50 PM by elephant. 5 replies.
Page 1 of 1 (6 items)
  • 03-26-2010 4:36 AM
    spdif cable
    i have been told by the man who fitted my sky hd box i need the cable fitted for audio
    can someone please tell me where you connect this on the hd box and connection on the tv.
    my tv is a beovision 10
    your help needed  please
    malcolm
    my system is a beovision 10, beocentre 2 dvd/cd, beolab2 beolab 8000
  • 03-26-2010 6:01 PM In reply to
    Re: spdif cable
    The product page of Beoworld gives better details than the B&O site !
    http://www.beoworld.org/prod_details.asp?pid=1276
    It states that the BV10 connections include:
    • Digital audio inputs 1 x Phono SPDIF 1
    You need to find the similar connection on your sky HD box.
    Or are you saying you are not sure which physical position on the units to plug the cable in ?
    [update]
    I downloaded the BV10 User Guide from Beoworld (I am a Gold member) ... look on page 40 of your User Guide manual for the connections ... you should have received this manual with your system.
    Ed
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 03-27-2010 5:12 AM In reply to
    Re: spdif cable
    many thanks for your reply, ordered english manuals as i live in spain unfortunately these delivered to the shop  and sat in their office before receiving now arrived
    many thanks again
    malcolm
  • 03-27-2010 7:09 AM In reply to
    Re: spdif cable
    being a gold member of this site is a very worthwhile thing
    it supports the site
    and it gets you the manuals you need
    and a chance in the monthly lottery
  • 03-27-2010 8:29 AM In reply to
    Re: spdif cable
    yes i know im a founder gold member
    but did not look in manuals silly me, put down to a senior moment.
    thanks once again
    malcolm
  • 03-27-2010 1:50 PM In reply to
    Re: spdif cable
    even sillier me for not looking at your avatar !
