Latest post 05-31-2010 4:19 PM by Steffen. 4 replies.
Page 1 of 1 (5 items)
  • 03-25-2010 6:35 PM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    Beolab penta 2 display help!!!!!
    hi i have a pair of penta 2's but one of them the display has gone funny (my fault as i took it apart to see if the back light could be changed) as the 2's are a bit dim but when i took the metal cover of the lcd screen i found they cant be changed so i put it back together but now its just blank??, although still lights up ok.
    i have moved it about and i can get a partial display but then it goes of!
    please can someone advise if it can be fixedSad
    thanks
    mark
    Kind Regards, Mark
  • 03-25-2010 7:10 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beolab penta 2 display help!!!!!
    Could you have pulled too hard in the cable, causing it to losen at the amplifier end ?
  • 03-25-2010 7:29 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    i only removed the lcd part with the thin flat flexi ribon cable and i left the main part in the speaker it was only after i removed the lcd screen from the board and the rubber connecting parts fell off (i made sure it went back the correct way) i think its just a matter of getting the screen to make contack with the board agian (last time i touch anything as i only seem to make thing 10x worseSad)
    mark
    p.s havent forgot about the belts for the 2500 (just waiting for some spare cash)
    Kind Regards, Mark
  • 03-27-2010 6:00 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    just a quick update, i have just dropped the lcd screen and its cracked!
    does anyone know if these are still available from b&o? part number 8330243 if not does anyone have an old one they are willing to part with?
    mark
    Kind Regards, Mark
  • 05-31-2010 4:19 PM In reply to
    I don't think you can get an original display any more -but you can get another that fits.
    Have a look at this:
    http://home.swipnet.se/ridax/display.htm
    Steffen
