Latest post 04-06-2010 1:08 PM by Medogsfat. 5 replies.
Page 1 of 1 (6 items)
  • 03-24-2010 2:05 PM
    How to connect 7 Pin DIN to 5 Pin DIN BM
    So I bought a used 4004 TT with 7 Pin connector and my BM 3000-2 has 5 Pin connections.
    Went to eBay and was searching for adapter/converter and saw an ad for a 5 pin to RCA and in his ad he adds that if you have 7 Pin connector you can....And I not sure what he is saying becasue of language issues, but thought he might be saying you can exclude pins 6 and 7 and then plug it in. Here are his exact words "If do you have a 7 Pol DIN male plug ,usually are  pin 6+7 screwed, it's can be removed."
    Was wondering if anyone can add or clarify this.
  • 03-24-2010 3:56 PM In reply to
    Re: How to connect 7 Pin DIN to 5 Pin DIN BM
    You need a very small screwdriver. Pins 6 and 7 unscrew - you will notice they have a small slot in the end of them. Chris has a good suggestion in that you should tape them to the lead once unscrewed.
  • 03-25-2010 4:56 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Here's a photo of a 7 pin DIN plug with pin 6 removed & pin 7 still in place. You can just make out the screw slot on pin 7.
  • 04-06-2010 4:40 AM In reply to
    • Claus
    • Not Ranked
    • Joined on 11-05-2009
    • Copenhagen
    • Posts 41
    • Gold Member
    I've got a Beomaster 2400-2 and a Beogram 2400 - but the -gram is missing pin 6 and 7 in the DIN-plug (so the remote-function is not working).
    Anybody know how to get these? Any help will be appreciated – thanks!
    - Claus
    Beolab 5000 (x2), Beomaster 2400-2 & 5000, Beogram 2400/MMC20E, Beovox S30, S45 & S75, M75 - and growing...
  • 04-06-2010 6:05 AM In reply to
    You actually only need one! Only one pin is active. Martin has them I believe but they are not cheap - they take quite a bit of skill to make just the right size! The alternative is to take one from another product - as I said - they only need one!
  • 04-06-2010 1:08 PM In reply to
    • Medogsfat
    • Posts 4,045
    You only actually need one pin to carry the datalink. I forget which one it is but chances are you will screw it into the wrong hole first time & have to then switch it over.
    Very hard to get hold of now but fortuantely (for youSmile) it's the sort of thing I tend to hoard so I have a spare if you PM me your address.
    Chris.
