Latest post 03-23-2010 11:14 AM by Santiago. 3 replies.
Page 1 of 1 (4 items)
  • 03-23-2010 9:05 AM
    Beo5 "V.TAPE2" BeoIR code?
    Hello everybody,
    I'm sure this has been asked before, but I cannot find it in this forum; I'm sorry for that...
    I'm looking for the beo5 "BeoIR code" equivalent to the "V.TAPE2" beo4 command.
    I have a Panasonic DVD player connected to my avantDVD in the "AV" scart using a DVD-controller for some years; with the "V.TAPE2" option in the avant connections menu; the problem is that some days ago I've lost this "V.TAPE2" activation code in the beo5 Confused; but my beo4 still works well.
    In the V.TAPE scart there is a HDR2 connected, so "0:000:TV:VTR" starts the HDR2;
    I've also tried "0:001:TV:1:VTR" and "0:001:TV:2:VTR" without success Sad
    Thanks a lot in advance.
    Santiago
  • 03-23-2010 9:22 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Beo5 "V.TAPE2" BeoIR code?
    Try DVD2, and try in VTR mode, not TV mode....
    Stefan
  • 03-23-2010 11:05 AM In reply to
    stefan:
    Stefan
    Hello and thanks Stefan,
    I've tried your suggestion but it doesn't work.
    The name "DVD2" is the "VTR" IR command, so the beo5 IRcode finally is "0:000:VTR:VTR", and this code starts the HDR2 with the command "V.TAPE" turned on in the avant display.
    I need select and see the "V.TAPE2" command in the avant display ! crazy that beo4 does it so easily... Embarrassed
    Santiago
  • 03-23-2010 11:14 AM In reply to
    SOLVED!!!!!!!!!!!!!!!!!
    "0:001:VTR:1:VTR"
    Thank you Stefan!!!! the key was to use the VTR mode, not TV mode, exactly as you suggested.
    Santiago
