Latest post 04-05-2010 9:47 AM by Ehlerz. 10 replies.
Page 1 of 1 (11 items)
  • 03-22-2010 1:26 PM
    BV7-40 - Noisy Fans
    Hi All
    I have just bought a new 7-40 with integrated DVB & Blue-ray player.  Beautiful TV but I am really disappointed with the noise the fans make.  At low volume and during quiet scenes its almost unbearable!
    Does anybody else have this issue?  I have been in contact with my supplier and they are lookig into it but I am not sure how we fix this problem (I cant beleive a TV this expensive doesnt have the quietest & most efficient fans in the market!)
    Any advice is greatfully received.
    Paul
  • 03-22-2010 3:18 PM In reply to
    • richu
    • Not Ranked
    • Joined on 10-02-2009
    • Switzerland
    • Posts 75
    Re: BV7-40 - Noisy Fans
    Cold comfort, but some hope. You might want to subscribe to the below thread. It seems you have SW 7.0.5 which should be updated (hopefully).
    http://forum.beoworld.org/forums/p/31193/251349.aspx#251349
  • 03-22-2010 4:42 PM In reply to
    Hi
    Call your dealer and have him install SW 8.02 on your new tv. This should solve your trouble.
    We are many who experienced the same issues. Also be aware that there also is a new DVB-HD update to be released in week 14. This will hopefully solve the many troubles with the module.
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 03-23-2010 3:41 AM In reply to
    • richu
    • Not Ranked
    • Switzerland
    • Posts 75
    Hi Ehlerz,
    can you confirm, that 8.02 resolves the issue with the high fan speed?
    Have you installed it on your 7-40 MK IV (and have you had 7.05 previousely)?
    I will call my dealer, when multiple 7-40 owners confirm, that it has been resolved and no other major bugs have been introduced.
  • 03-23-2010 4:38 AM In reply to
    Hi Richu
    I had the 7.05 but downgraded to 6.11 after experiencing noisy fans. The 8.02 update should as i am told resolve this issue, but i will get back to you later today when i myself have it installed.
    /Ehlerz
    Updated: SW 8.02 solving fannoise confirmed! Furthermore, smoother moving electronic curtains, and possibly also more stabile digital information in the top of the screen when switching channels.
  • 03-23-2010 6:31 AM In reply to
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    I had my 7-40 mk IV upgraded from 6.xx to 7.11a, due to the TV showing an overheatning message some times.
    Did not have the fan noice before and do not have it after.
    /MikaelB
  • 03-23-2010 1:56 PM In reply to
    Thank you everybody for the replies so far - very helpful.
    Paul
  • 04-04-2010 6:36 AM In reply to
    Hi Ehlerz
    Has updated SW to 8.02 fixed the fan problem?
    Paul
  • 04-05-2010 7:37 AM In reply to
    Hi Paul
    It has yes, no more trouble with fan noise.
    If you update your tv, then wait till also the new DVB-HD update is available. (week 14 i was told)
  • 04-05-2010 7:55 AM In reply to
    Thanks Ehlerz.  What does the new DVB-HD update do/fix please?
  • 04-05-2010 9:47 AM In reply to
    Hi again
    Apparently the update fixes slow channelshifting, slow loading EPG function, and introduce more overall stability. Furthermore, the DTV startuptime should be less than it is now.
    /Ehlerz
