Latest post 03-23-2010 4:44 AM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 03-22-2010 11:24 AM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    Beosystem 2500 tape deck sound??
    hi i have just bought a beosystem 2500 (in new condition) but when i play any of my tapes they sound strange a bit warbley (like a bird's noise) i have cleaned the heads but still sounds the same?
    does anyone have any idea's i.e bad capacitor's.
    many thanks
    mark
    Kind Regards, Mark
  • 03-22-2010 11:38 AM In reply to
    Re: Beosystem 2500 tape deck sound??
    Maybe you need new belts? Sounds like wow and flutter.
  • 03-22-2010 2:24 PM In reply to
    Yes, replace the belt(s).
    If Radio and CD is fine, then the caps are no problem with this drive.
  • 03-22-2010 2:27 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    thanks, any idea if b&o still do them or do you know where i can get them from?
    regards
    mark
    Kind Regards, Mark
  • 03-23-2010 4:44 AM In reply to
    Send a PM to member Dillen as he can supply.
    Regards Graham
