Latest post 06-30-2007 6:30 PM by Max. 10 replies.
Page 1 of 1 (11 items)
  • 06-20-2007 6:10 PM
    • Max
    • Not Ranked
    • Joined on 04-19-2007
    • Devon
    • Posts 64
    BeoSystem 3 Issue?
    Has anyone ever experienced a blinking red LED on the IR Receiver after setting the BS3 to standby?
    The BS3 is connected to two AV sources via SCART, screen via DVI, DVB-T module installed, BL9's, BL7-4 and BL6000's with a ML to a BS3200and BL3500. It's on SW 2.60a and appears to be functioning properly with no adverse affects.
    Thanks in advance.
    Max.
    My B&O is in my Bio.
  • 06-21-2007 4:23 AM In reply to
    • Beonut
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Essex, UK
    • Posts 89
    Re: BeoSystem 3 Issue?
    Mine occasionally does that as well, dont know why. I am on sw 2.7.
    Regards
    Peter
    My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
  • 06-21-2007 5:51 AM In reply to
    • Corvin
    • Joined on 04-16-2007
    • Australia
    • Posts 124
    Noticed it on mine too. Also running 2.7.
    I thought it was after i made some change to the system. Seems ok now.
  • 06-21-2007 4:15 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    Thanks for the updates. I called my local dealer to check and they weren't sure but offered a few suggestions (PIN code, dismissed at not the problem as it can be used ok, and timer settings). I checked the timers and re-confirmed one of my AV connection configs and the blinking LED has gone. I'll call them tomorrow to see if they can get technical to confirm the reason.
    Also, after reading the service manual, I checked the service menus and there are errors on the initial screen (TV 0621 34-2E) and the history is peppered with IO_ERROR and APPLICATION_ERR, is it common to have this many errors? I'll have a look at the error charts in the manual and see if I can make sense of them.
  • 06-21-2007 5:59 PM In reply to
    Yes that normal, when powering on the main procceser check all moduel's and f.ex. the sound processer is'nt ready to reply.
    so its only a software blob no error..
  • 06-21-2007 6:18 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    Thanks Bang1.
    I traced the errors and there is only one which specifically states replace AVS board (APPLICATION_ERR - ERROR_CODE: 00F8 - PARAM: 00050051) and a couple of xx:xx:00:03 - for future use, so I'll raise this with my dealer tomorrow and see what transpires.
  • 06-22-2007 6:58 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    The dealer has spoken to technical and there is no obvious reason for the blinking LED, but possibly due to the connection to a non B&O screen. It seems strange that they would go to the trouble to make it blink without a good cause - maybe it's a subliminal message telling me to get a BV4!
    Anyway, I discussed the errors and will be put in touch with one of the engineers next week to see whether my BS3 needs some special attention.
  • 06-25-2007 4:48 AM In reply to
    • Beonut
    • Essex, UK
    • Posts 89
    I get the blinking red light (without a green light) and I have the b&o plasma. The reference guide also points out (although I dont think this is the problem) that flashing red then green is warning of overheating in the bs3.
    Regards
    Peter
  • 06-25-2007 2:14 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    Thanks Peter, glad to hear it not just with kikinoko screens. Interestingly I noticed after a bit more analysis at the weekend, the errors were only being logged when the system was being put into standby. It seemed they were being logged in the VMEM log every 2 minutes after power off and didn't appear to be added to the NVMEM log. There were TV mmdd 34-2E errors on the initial screen and IIC2E-34:ACK_MIS with PARAM: 01013406 and on closer inspection the led on the BS3 itself was staying on green.
    I decided to power cycle the unit and it was only then that I realised the led on the BS3 wasn't supposed to be on when on standby. It looks like during the standby process something was preventing it from shutting down and, I guess, it was trying every 2 minutes to do something. Maybe this is what the blinking red led signifies - that the unit is not shutting down and it's in a state of retry. I'd be interested to know if you see the same when you next get the situation.
    Anyway, I still have the APPLICATION_ERR - ERROR_CODE: 00F8 - PARAM: 00050051 (along with 08000003 & 00010003) in the log, awaiting the call from the engineer as this looks more serious based upon the service guide info.
  • 06-30-2007 10:16 AM In reply to
    Hi
    There came a new SW update 3.1, June 21. that should solved problem when powering off..
    But don't know if it's this B&O mean by power off Problem (blinking red)..
  • 06-30-2007 6:30 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    The service engineer visited today and upgraded my Beosystem 3 to SW 3.1 - maybe this is in response to a fix for this problem. I'll update this thread with any future findings.
