Latest post 03-22-2010 4:21 PM by david707. 20 replies.
Page 1 of 1 (21 items)
  • 03-20-2010 6:12 AM
    • dueno
    • Top 500 Contributor
    • Joined on 04-29-2007
    • bordeaux
    • Posts 147
    bv 7-55 vs bv10-46
    what is your choice???
    never explain never complain
  • 03-20-2010 6:28 AM In reply to
    Re: bv 7-55 vs bv10-46
    I'd have the lower setup, but that's simply because I hate that "triangles dripping off of things" design concept...
    -mika
  • 03-20-2010 6:41 AM In reply to
    i would definately go for the top one and i don't think that you would regret it for a minute. i actually saw the bv7-55 the other day and i think its one of the nicest looking tvs out there right now.
  • 03-20-2010 9:21 AM In reply to
    • dueno
    • bordeaux
    • Posts 147
  • 03-20-2010 5:02 PM In reply to
    that looks like that would suit your room perfectly i think you should go for it.
  • 03-20-2010 5:13 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    markiedee:
    I'm not so sure. I think it visually overpowers the Lab 3's. The "BV10" looks a lot less domineering.
  • 03-20-2010 5:40 PM In reply to
    I agree with Puncher, but I think you should upgrade to 9s rather than downgrade to a BV-10!
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 03-21-2010 3:37 AM In reply to
    One other point - I note you have a Beocenter 9500 or 9300. The BV10 will not work with a Beolink converter so will not link with your audio in a link system.
  • 03-21-2010 5:46 AM In reply to
    Are there any more TV's in the current range not backward compatible like this?
  • 03-21-2010 11:40 AM In reply to
    The BV8 for one.
  • 03-21-2010 4:07 PM In reply to
    • dueno
    • bordeaux
    • Posts 147
    I don't no that some of the new TV were not compatible with the beolink converter(1611)!!!!!!
    so now I have the choice between the bv7-55 or a bv9 second hand......
  • 03-21-2010 4:15 PM In reply to
    I would have the BV9 every time! Especially if fitted with some of the extra modules. The other advantage of either the 9 or 7 is that they can act as a video master and have timers built in which the BV10 lacks. This is quite a disadvantage and relies on one having a suitable audio master or a Beocenter 2.
  • 03-21-2010 4:19 PM In reply to
    • dueno
    • bordeaux
    • Posts 147
    how is it possible that the bv 10and bv8 are not compatible with beolink converter????
    • dueno
    • bordeaux
    • Posts 147
    my dealer never say that to me!!!!!
  • 03-21-2010 4:48 PM In reply to
    Get him to check - he will confirm it! I imagine it will have effects in link rooms.
  • 03-21-2010 4:58 PM In reply to
    • dueno
    • bordeaux
    • Posts 147
    why is it ok with bv 7and 9 and not with bv8 and 10 (because they hve no timer???) the masterlink plug is different?????
  • 03-21-2010 5:12 PM In reply to
    It must be the data sent in the link is different. I do note that the BV10 does not send information to displays on speakers whereas the BV5 does for instance. I guess the chassis is missing some of the more complex features.
  • 03-22-2010 7:07 AM In reply to
    • dueno
    • bordeaux
    • Posts 147
    beocare service say to me that beovision 10-40 is compatible with beolink converter
  • 03-22-2010 11:40 AM In reply to
    I'll send you something when I get home!!
  • 03-22-2010 3:16 PM In reply to
    I see the issue! They have just upgraded the software this weekend! Software build 109b allows use of the beolink converter . The have also added a game mode and a DTV play timer - all improvements worth having.
  • 03-22-2010 4:21 PM In reply to
    Panic over. I thought B&O were discontinuing MCL compatibility. ...But why was something so essential overlooked when the TV was introduced? I assume it's an expensive dealer visit to update the software? If these improvements are "worth having" they should surely have been available 'out of the box' rather than a few months later as an afterthought. Thankfully my Avant and LX seem to have been properly designed  at the factory.
