Dear Readers,
After discussing my wishes/ needs/ budget etc at the Dutch section of the BW-forum I've purchased a Beosound 2300 after spotting a great deal including BL2500, a wall bracket and guarantee. It is the later version with vertical laser but I think it's fitted with a small clamp. (?)
It didn't even arrive yet... with luck tomorrow, more likely at the beginning of next week but...
While browsing I've found a new RDS kit for 70€ and am actually considering it. Is it reasonably priced you think?
Reasons why I'd like to "upgrade" to RDS are mainly the ability displaying;
Clock and Time (CT), Radio Text (RT), Programme Type Identification (PTY), Programme Identification (PI), Programme Service Name (PS)
I don't have a two way remote and didn't plan on buying one. Beo4 is my friend.
Knowing that some of the early BC2300 had RDS and were recognizable by a little window at the left down corner of the Beocenter. What about a center without this window when fitting an RDS kit?
Any information or suggestions appreciated.
Regards,
Maurice
