Latest post 03-17-2010 4:08 PM by Dillen. 2 replies.
Page 1 of 1 (3 items)
  • 03-17-2010 1:45 PM
    Beogram 1200 doesen't work
    I have a Beogram 1200 and when i move the pickup arm towards the center the plate doesen't move.
    The Beogram hasen't been played in many years.
    Do you know whats wrong?
    Best Regards Erik
  • 03-17-2010 2:44 PM In reply to
    Re: Beogram 1200 doesen't work
    Obviously impossible to diagnose properly on line but I would suggest looking at the following:
    1. Corrosion on the contacts - very likely if not been used for a long time.
    2. Motor seized - try spinning the platter by hand as you move the arm and see if that starts it up. If it does, let it run for a good long time.
    3. Cracked solder joints or defective component - you will need to search for this one.
    4. Check the belt is on! Big Smile
  • 03-17-2010 4:08 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Welcome to Beoworld !
    The motor will not start because you move the arm (like Beogram 1000 etc.).
    You must select record size and speed and then press the black start button.
