Thanks. The online manual listed that command, whereas the paper manual I have does not have that. So if I'm playing the radio from the 4500 through the speakers connected to the avant, the Sound button brings up the bass/treble commands, etc, but there are no numbers lit up. However, if I press AV RADIO, then I can issue SOUND 4 and put the system into surround mode. Unfortunately, the 7000 stops displaying the volume and radio preselect number.
Although the online Beolink 7000 manual DOES say there is a STAND command, I can not find it in the menus. Have any hints? I did find that TV MENU will bring up the menu on the Avant, and if I select stand position, the AVANT WILL accept the number commands from the Beolink 7000 to move the stand. Not as cool as a direct STAND command, but at least a partial victory.
Always new adventures awaiting with B&O!
