Latest post 03-18-2010 1:20 PM by nobby. 6 replies.
Page 1 of 1 (7 items)
  • 03-14-2010 4:27 AM
    Setup of Beolab Penta Amps
    The service manual is rather unhelpful in its description ... it says connect voltmeter to 1R103/1R104 ... does this mean across the two resistors ... ie looking for 15mV on each? or 30mV across each resistor?
    Neil
  • 03-14-2010 6:05 AM In reply to
    Re: Setup of Beolab Penta Amps
    Across both resistors and 15mV in total. Usually there are testpoints printed on the board.
  • 03-14-2010 12:22 PM In reply to
    30mV  across both resistors,15mv across each.Clip your meter leads on to avoid shorts,and set the current with no speaker connected.Don't forget to set 'tother pot for zero dc across the output.
    If the thing won't set up,you may have ripple in the stand'by supply,best to replace ALL the caps!!
    Regards,
    Nick
  • 03-14-2010 1:17 PM In reply to
    Thanks guys ... but i have just found that before i can get to that, I have to get the orange light off ;)
  • 03-14-2010 6:53 PM In reply to
    Nick + others,
    Seems that the main supply caps are at the end of their life ... one is a direct short ... not good!
    Do you have a reliable source or choice for these?
    Neil
  • 03-16-2010 6:20 PM In reply to
    Cripes,thats the only cap I've never replaced in these amps!!
    You can get a suitable replacement from Farnell,No 471471,not sure about the dimensions,there is very little room for fitting as you know.Best to replace them both I guess.Not cheap !
    Regards,
    Nick
  • 03-18-2010 1:20 PM In reply to
    The "official" ones from B and O are about £25 a piece ... ahem ... we wont be using those!!!
    I have found another "source" which come in about a quarter of the price, I will let you know how I get on.
    The second amp (which had a different fault) is now up and running nicely ... I am very pleased :)
    Thanks for your help guys.
    Neil
