Latest post 10-17-2011 1:41 AM by SWISS_2. 31 replies.
Page 2 of 2 (32 items) < Previous 1 2
  • 06-22-2007 2:22 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: what's the problem of my beosound 3?
    B&O is in a lot of cases, not a lot more expensive than other brands once you get higher up in the price range. The BeoVision 4-65" and BeoSystem 3 is around the same price as Sony's equivalent, and although the smaller things in the B&O product range are more expensive than other brands in general, it's not 6 to 10 times more expensive. If you think durability is a serious issue, you should try using a 30 year old Sony set! My BeoVision 600 still works perfectly, although it is an exception, and in general even B&O TVs don't last quite that long. And when you say similar functions, they don't necessarily perform them to the same level as the B&O.
     Weekly top artists:
  • 06-22-2007 10:21 PM In reply to
    • Beo
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 108
    haha, thanks for your reply. Please don't take it serious. It was just something I only said in the days without my BS3, maybe i am too boring. haha.
  • 10-16-2011 7:21 PM In reply to
    • zag
    • Not Ranked
    • Joined on 10-17-2011
    • Posts 2
    Beo, was your problem resolved? I have the same issue but more severe - my unit turns on the radio at random and changes channels and volume all by itself! Is this thing alive?
  • 10-16-2011 10:19 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    It's a well-known problem.   Replacing the top panel fixes it.
  • 10-16-2011 10:26 PM In reply to
    • zag
    • Not Ranked
    • Posts 2
    Thanks mediabobny - any idea how much it would cost in the USA?
  • 10-16-2011 10:44 PM In reply to
    • mediabobny
    • Posts 336
    Afraid not; certainly nothing if it's still under warrantee.  And since they know of the problem, you might get lucky.
  • 10-17-2011 1:41 AM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    After the Beosound 3 was introduced, I debated on buying one or not.
    I happened to be in a B&O store later, talking to a Danish employee about the Beosound 4 I had just purchased. The Beosound 3 came up, and the employee mentioned the top plate having problems, which I had not been aware of. No attempt to concel that fact at all. He demonstrated a unit that had gone out for a top plate replacement. The owner had changed her mind about accepting it back.
    I liked the sound. He assured me that the replacement solved the problem, and after trying a few SD cards of music on it, I bought it.
    I would have been as disappointed as you were to find there were design flaws with the original top plate, had I purchased it new. But knowing the problem could be fixed, and in my case was, our BS 3 has been a good companion in the house, garden, boat, and on picnics.
    The new Bose radio I tried out recently does not come close to the sound of the BS 3: If one reads the Bose reviews, there are more serious problems and complaints with that model.
