Hello guys, who can help me??
I've replaced all the caps (of the lower PCB board) of my Beogram CD5500 and everything is working fine, even CD-R now.
But when I mount into the tracklist by pressing play on the front, I cann't always skip all the numbers until the last tracks!?
The player goes then in standby, what would be the cause of this??
The 3 or 2 last numbers of the disc are the most difficult to select, the others are no problem!
The strange thing is, when I let it play without selecting any track manualy, the whole disc is playing faultless!!?
Is there a difference between HR and TK capacitors? I've used 100µF/16V TK (Jamicon), 220µF/16V HR (Choyo), 1,5µF/63V bipolar (Wima) and 47µF/40V axial (Philips blue). Are the voltages also OK??
Regards, Bruno
