Thanks Lee!
To summarise the different cable versions:-
Powerlink mk.1 is only suitable for the simpler Beolab speakers (ie. those without displays or digital amps. They are very thin and I personally won't sell them as I'm not too happy with the sound quality on longer cable runs.
Mk.2 cables (aka. "fully-wired") have all 8 pins connected and will work with any Powerlink-equipped speakers, including Beolab 5 and all models with displays. As Lee has said, these are the best bet if you think you may change your speakers in future, as you know you won't need to replace the cables. I use them all around the house, as they work well with any speakers.
Mk.3 cables have extra shielding (as mentioned by joeyboygolf) to ground the digital amps in newer speakers, but they lack the data wiring for Beolab 5 or speakers with displays.
Kind regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
