Latest post 03-12-2010 10:42 AM by Stonk. 1 replies.
Page 1 of 1 (2 items)
  • 03-12-2010 9:52 AM
    • msiegw
    • Not Ranked
    • Joined on 09-08-2008
    • Posts 4
    Beolink without eye in Bathroom
    I would like to install in the bathroom a Beolink. I'm afraid of using the remote controll in the bath. I don't want that a remote controll of 200 Euro falls into my bath and get destroid. I know there are cheaper 3rd party remote controlls. But the problem will be the same only less money is getting destroid. I would like to ask if there is something (probably 3 party device) similar to the eye which allows you to controll the music. For instance to change the radio station of switch CD/radio? With the eye you only can change the volume and turn it on/off.
    regards,
  • 03-12-2010 10:42 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beolink without eye in Bathroom
    So what you want is the buttons to operate your system mounted on a wall? Easiest solution would be and eye and a 2nd hand Beolink 1000 in it's wall mount. The BL1000 will happliy work in it's mount and you'll never have the risk of dropping it in the bath.
    If you think nobody cares, try missing a couple of payments.
