I've been working on this project for about a week now, here's the deal:
Lots of Beomasters and Beocenters only have one available TAPE input. On some systems, there's actually no additional input available, or it's built with RCA jacks. Now with the advent of new media devices like HTPC's, set-top boxes, Blu-Ray players and a various arrangement of game consoles cluttering the living room, I deciced to start drawing some things up and find a way to plug all of that stuff into our existing B&O audio rigs.
I took a little bit of artistic freedom (eh, cheat) and looked at simple examples of audio mixing desks, which are simple adder circuits to combine several audio inputs.
The current ("version 1") design I intend to use for testing with my own system, is a multiple input, active mixer circuit. It offers mixing of stereo line sources, such as a tape player, CD player, BluRay deck or console, and throws everything onto the main output at the same level. If you're familiar with op-amps, the circuit should look fairly straightforward and easy to construct.
The easiest way to do this is to tie all of the sources together with resistors, which works, but you will lose 6dB of signal with each source. An active mixer design, like this, works better, can be expanded to an unlimited amount of signal sources (at the L*_IN and R*_IN points), and can even be converted for differential signal output if you really need it.
Obviously, this is a preliminary design, so it has a few drawbacks as well. First of all, the Datalink is tied together in quite a dumb fashion. This isn't really an issue if you have devices that have no or only one-way communication capability, but might cause a few hiccups if you connect more devices and they start having quite extensive conversations with each other. 2 Beocords on this line might start a serious argument.
 A smarter way of handling Datalink (with outside communication, either wired or wireless) is on the way. Hurray for the magic of microcontrollers in this case!
Secondly, and this is currently the most important drawback: If you have an unconnected source, its level is fixed, so the 'fader' for that source will stay open. Which may be causing noise to arrive at the amplifiers input, ruining your pretty signal you just got out of that expensive 192KHz/96-bit D/A converter, without having a clue how it got there. Again, a muting circuit for each input is being worked on.
The inputs are standard LINE inputs and can be built with 7-pin DIN plugs (recommended if you want to connect B&O gear), or any other plug you prefer for your line level signal. RCA is a popular choice, but 5-pin DIN and TRS are not uncommon, and I'm personally a fan of RJ45 plugs and CAT5 cabling to carry audio and digital control signals around the house in a neat, inexpensive fashion.
The power supply isn't quite that impressive. It takes 9VAC from a standard wall plug adapter (available at music stores to power guitar stomp boxes) and straightens it out for +/-5VDC. Any more voltage swing is not required anyway.
