I have a Beovision TV Model MX3500 and it has the following problem: I switch it ON and either it is appeared a black screen and you may listen only the voices or if it comes up normally, suddenly the colors dissapear and you can see the picture in black and white or becoming black screen again.
According to local B&O service the "module" for the color is damaged and there is not available as new from B&O any more.
My question is: Is there any possibility that I can find such a module or in the worst case, a damaged MX3500 so to remove any module or electronic part from the damaged one.
