Latest post 03-10-2010 5:24 AM by fgwemmel. 2 replies.
Page 1 of 1 (3 items)
  • 03-07-2010 1:25 PM
    beogram 6002 - stylus pressure adjusting part
    I have bought a old Beogram 6002 in a second hand market (22 Euro !!!). A nice vintage turnable.
    After cleaning, oiling and tuning everything (following the service manual that I have download on the net), it works fine.
    The only problems I have are :
    1) the lamps indicating the RPM 33 or 45 are not very bright : I have still to check the voltage
    2) I don't see any stylus pressure adjusting part, except the counter balancing weight wich is to be place  so that the arm is floating when the pressure is set to 0 gr. I think that there a part lost lost.
    Could somebody send to me a picture  or a drawing of this part, with, if possible, some dimensions, so that I could make a one by myself ?
    (I could find a little balance to mark the scale).
    Thank you very much
  • 03-07-2010 3:56 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beogram 6002 - stylus pressure adjusting part
    Welcome to Beoworld !
    The tracking force is set using the pointer at the right side of the tonearm.
  • 03-10-2010 5:24 AM In reply to
    Thanks Martin, I've found it (the cursor is so discreet and usualy hidden when the tonearm is on the right side). Thanks again for such a quick answer.
    Freddy
