Latest post 03-09-2010 4:12 AM by richu. 7 replies.
Page 1 of 1 (8 items)
  • 03-07-2010 9:12 AM
    Beovision 7-40 and speakers
    Hi, I have a problem with the speakers that is connected to the TV, I have 7-2 and beolab 3. I was thinking to use the 7-2 as front and beolab 3 as rears. When I go to the menu i have assigned beolab 3 to the right connections, and then in speakerroles when I try to choose the beolab 3s as left and right surrounds, I is not possible to hit go, nothing happens. Am I missing something here? Is it impossible to only have 7-2 and rears?
  • 03-07-2010 10:51 AM In reply to
    Re: Beovision 7-40 and speakers
    I think it is impossible to have rears unless there are fronts.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 03-07-2010 11:16 AM In reply to
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Agree, I think it is impossible.
    i also wonder, why not use the bl3 as front speakers? I would prefer to have a center and two fronts over a center and two rears.
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 03-07-2010 11:32 AM In reply to
    • richu
    • Not Ranked
    • Joined on 10-02-2009
    • Switzerland
    • Posts 75
    You must first configure the front speakers left and right.
    Afterwards, it is possible to configure surround. But perhaps only, when you have a center. So the BL3 might only be configured as rear left/right (not surround left/right) unless you have a center.
    Surround is defined as 5.1 or 7.1, hence you might need a center (.1).
  • 03-07-2010 12:13 PM In reply to
    Yes
  • 03-07-2010 4:43 PM In reply to
    i Have tried that once asswell back in the days and indeed its impossible...
  • 03-08-2010 5:22 PM In reply to
    OK,Thanks for helping.
  • 03-09-2010 4:12 AM In reply to
    • richu
    • Not Ranked
    • Switzerland
    • Posts 75
    You might want to talk to your dealer who proposed this solution.
    Having wonderful BL3 and buying another BL 7-2 stereo speakers doesn't really make sense. You might want to change the BL 7-2 to 7-4 and then using the BL3 as front left/right (again).
    I have BL4 as surround. Yes, not really high capacity speakers. But for our room they fit perfect and nice and for surround, they are great. And the BV7 really has a cool Dolby Engine which creates impressive 5.1 even when getting only PCM sound instead of full DD 5.1.
