Latest post 03-08-2010 4:02 AM by stotty1111. 4 replies.
Page 1 of 1 (5 items)
  • 03-05-2010 9:29 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    MX7000, BS4, BL4000, and converter box - setup probs
    Hi all,
    Not sure if this is correct forum!
    Gort the above bits of kit, the bs4 is ml'd to the converter box which is in turn audio linked (7pin lead) to the MX the BL's are linked into the tv as well as a dvd1 and a vcr8000 - problem, used the pcg system to program it all - tv / vcr / dvd all work fine the bs will not boot up using a bl1000 or a beo4 - the tv is set up with powerlinks active etc but the bs will not talk to the tv or infact rreact to the remotes when programmed as per the pcg the system has also been setup as per the bs handbook with the same result!
    If i replace the bs with an ouverture the system works perfectly - what am i doing / have done wrong?
    pcg audio - option 0 video option2.5
    manual audio - 0 video - 2
    Everything in one room
    hellllppppppp!!!!!!!!!!!
    Its a beautiful afternoon here in finistere and have the pastis at hand however i would like to get the prob sorted before i hit the bottle!
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-06-2010 5:22 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: MX7000, BS4, BL4000, and converter box - setup probs
    Hi all
    Sort of bounce     ------
    but tried it tother way with the bl's off the bs4 and used audio 1 video 2 and low and behold it works - but come on guys can anyone explain why no good the other way with bl's off the tv
    its got me intigued!
    salut
    tony
  • 03-06-2010 5:39 AM In reply to
    Just guessing that it is something to do with master/slave relationship and the BS4 does not want to be the slave.
    I'm sure that someone with the knowledge will be along soon to confirm or otherwise.
    Regards Graham
  • 03-06-2010 2:25 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    graham,
    you've confirmed a thought i had this afternoon whilst idly stood machining some ali shelf brackets - I suppose it might be backward compatibilityetc as the mx predates the bx by about 8 years or more with the tv although it has a multi std tuner in it so it must be one of the last batch
    struck me thinking of pc's which are always claimed to be backward compatible but most of the time never are!
    thanks
    t
  • 03-08-2010 4:02 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi all
    An update - possibly egg on face time - because of relaying cables etc yesterday the units were unplugged etc from mains supply - and later rebooted so to speak -  worked fine in the last configuration , however thought I'd give it another go with my preferred config setup ie tv master bs slave et viola as the lingo here goes it worked fine - hey ho back to the original cable config!
    I suppose the lesson is - always assume a logic problem and try rebooting the whole thing before shouting HELP!
    All well now and I'm a happy bunny again!
    salut
    Tony
