Latest post 03-05-2010 7:57 AM by Puncher. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • 03-03-2010 4:29 PM
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    How to, cassette to pc.
    Can anyone help, i have a c90 cassette recording which i want to somehow put onto my pc, to then make available on say youtube or similar.???
    Cheers sandy
  • 03-03-2010 5:09 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: How to, cassette to pc.
    rfc1:
    Cheers sandy
    Do you have any cassette player at all?
    Any tape "out" output would be at line level and would record to a pc (line in) OK . Decent PC software would help to establish the best recording levels etc. Good trial versions are available for short term use - my preference is Adobe Audition (the BBC also use it). Once recorded in wav format it can be saved in any other format to suit.
  • 03-04-2010 2:56 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    I have both beocord 6500 and an ouverture.
    Thanks Sandy
  • 03-04-2010 3:19 AM In reply to
    You're all set then Sandy, all you need is a suitable cable and the software. I would probably use the 6500 (definitely if your recording happens to use Dolby C).
    You will need a 5-pin DIN to 3.5 mm stereo plug adapter. Note that a generic "iPod to B&O" cable with those connectors will not work, as it is connected to the input pins in the DIN and you want the signal that comes out of it.
    I would get a DIN to 4xRCA adapter (which covers both directions) and a 2xRCA to 3.5mm plug adapter, those will be useful for the other need as well.
    Then just hook it up as Puncher explained, press play and tweak until you get the signal in your recording software.
    -mika
  • 03-04-2010 3:23 AM In reply to
    • Puncher
    • Posts 9,588
    Blast - I've just typed a quite lengthy post only to find Mika has beaten me to it!
    Nevermind sounds like you're almost good to go!
    A good freeware sound recorder/editor is Audacity and can be found HERE - it will be good enough if you are only going to use it once or twice and is quite a small download, a free months trial of Audition can be found HERE although it is a much bigger download (~300mb).
    (If you intend to do a lot of audio editing/recording go for Audition, it's a professional application).
  • 03-04-2010 3:59 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Thanks. So i need 2 different cables and what ? Join them together.?  Sorry totally not sure on this one.
    sandy
  • 03-04-2010 4:20 AM In reply to
    • Puncher
    • Posts 9,588
    Whay Mika is saying is that you need to connect from the left & right outputs of your beocord to a 3.5mm stereo jack plug to go in the "line-in" of your pc. The output from the Beocord is actually a din plug carrying both L&R In&Out and so some leads (like the ipod type he describes) will have the 3.5mm plug connected to the input pins of the din plug to allow you to record external sources on your tape recorder.
    Unless you are certain that the you are buying has the output pins connected to the 3.5mm jack, Mika is recommending getting a generic "Din to Phono" lead which converts both stereo in and out from the beocord to 4 off phono plugs. This together with a 2 x phono to 3.5mm plug adapter will allow you to configure the lead you need.
    If you want a one stop shop ask Steve@sounds heavenly (link at bottom of page)
  • 03-04-2010 5:49 AM In reply to
    PErsonally I'd use one of these:
    http://www.amazon.co.uk/3-5MM-STEREO-CONNECT-PLAYER-FRONT/dp/B002KGD572/ref=sr_1_4?ie=UTF8&s=garden&qid=1267699687&sr=8-4
    Which would plug directly into the headphone socket of the B&O.
    Regards,
    Cal
  • 03-04-2010 6:01 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    would this work though?
    cheers Sandy
    • Puncher
    • Posts 9,588
    Callen:
    Regards,
    Cal
    This would indeed work, although you're then passing through the ouvertures headphone amp - I'm not sure of it's quality nor indeed that of the source material however, if you are just going to compress the resulting recording for posting on YouTube then such a lead will definitely do the job.
  • 03-04-2010 6:09 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Thanks Cal.  I will try this.  Just need to download the software 1st.
    cheers Sandy
  • 03-04-2010 6:12 AM In reply to
    I believe the headphone volume will need to be kept very low to avoid overloading the sound card input and distorting the sound, otherwise it'll be fine.
    No harm in trying, you might even have such a cable lying around somewhere (for example, some monitors come with one to connect the sound from the computer to the internal speakers).
    -mika
  • 03-04-2010 6:50 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    I have a b&o  din plug to  3.5mm jack plug, but it is configured to play INTO the B&O.   I could modify it if i knew what 2 correct pins to use ?
  • 03-04-2010 6:54 AM In reply to
    Leave the one in the middle alone, it is the ground. Then swap the two others to the opposite side pins.
    See the pinout for Audio AUX link and ignore the Datalink pins (6 and 7).
    -mika
  • 03-04-2010 9:20 AM In reply to
    I did record from Beogram to Beocord 6000 and then headphone out to pc line in.
    I've used Audacity to record it.
    I then put some pictures in window moviemaker along with the audio.
    It's uploaded to youtube.
    http://www.youtube.com/watch?v=qTf9-h6g3Kg&feature=related
    The song is Danish. Its only aviable on vinyl. My dear uncle were in the Danish grandprix 1979 with this. Other clips are on youtube from that and only a bit of this song so I uploaded it. He did not win.
  • 03-04-2010 1:10 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Ok Guys, i got it onto Audacity , no probs.  Thanks to all.
    My next question is where can i host the soundclip?  I tried youtube but as i converted the cassette to a WAV file Youtube doesnt want to know, probably as its not video??
    Its a vintage commentary of a football match on the cassette.!
    cheers Sandy
  • 03-04-2010 2:10 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    If you think nobody cares, try missing a couple of payments.
  • 03-04-2010 2:30 PM In reply to
    I believe Youtube really needs your content to be a video clip, that's why you'll always see at least a still image if nothing else. Unfortunately I don't know what kind of easy free solutions there would be for video authoring, but I'm sure someone else does. Also, rudimentary software for stuff like that usually comes bundled with DVD writers, digital cameras, and such.
    -mika
  • 03-04-2010 2:40 PM In reply to
    • Puncher
    • Posts 9,588
    Ok you can be the stand in stuntman for all of us!Big Smile
    Convert the wav to mp3 (I haven't played with Audacity for some time but I would think that if you open your wav from Audacity there would be a "save as" option to resave it as an mp3).
    Next you can try THIS - I never tried it or anything similar, I just came across it in a Google search (upload mp3 to youtube).
    As Mika says - youtube is really for video and so the link also needs a still photo to link to the audio.
    Let us know how you get on!Wink
  • 03-04-2010 2:43 PM In reply to
    • Puncher
    • Posts 9,588
    I admire your dedication for a vintage footy match commentary - I assume it's a special game.................one of Scotland's few victories perhaps!WhistleBig Smile
  • 03-04-2010 2:52 PM In reply to
    • Puncher
    • Posts 9,588
    A thought has struck me - I think you are limited to a max. clip length of 10 minutes on Youtube!
  • 03-04-2010 4:19 PM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Its a radio commentary of Rangers winning the league title in 1986/87 season.  After a decade in the wilderness, It was Graeme Souness' 1st season as Gers manager.!
    I know about utubes 10 min limit, but had made the clip just under.
    sandy
  • 03-04-2010 6:40 PM In reply to
    • Puncher
    • Posts 9,588
    rfc1:
    sandy
    Oops! - sorry about the Scottish thing!Devil
    Can I take it that mission is now accomplished?
  • 03-05-2010 2:55 AM In reply to
    • rfc1
    • Posts 166
    • Gold Member
    Not yet..  Am struggling to make the audacity file into mp3..  Try again later today.
    Sandy
  • 03-05-2010 3:22 AM In reply to
    • Puncher
    • Posts 9,588
    rfc1:
    Sandy
    OK - my fault(ish) - you need to go HERE and download the mp3 encoder plugin for Audacity.
    Follow instructions to find the encoder the first time it runs and "export to MP3" from Audacity's menu.
    (The mp3 bitrate can be changed from Audacitys preferences menu)
