Are there any affordable options for this? The Lutron 3103 seems perfect, but it is very expensive. Are there any other choices?
I am thinking of getting normal IR Lutron wall dimmers and switch to a Beo 5 - one should be able to program it to handle the lutron dimmer.
I am thinking about this right now, want to attack the topic this year.
If the 3103 is outside your budget, the single dimmers are the only option available, but they work very well.
I recently augmented my home system with occupation sensors and have found them to be the absolute ideal solution for most rooms. This way only my complex lighting zones are controlled via "scene" logic via keypads or remotes.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
Might this be a possibility?
http://forum.beoworld.org/forums/t/29414.aspx
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
jk1002 is correct, I have been contemplating a similar approach, I have a 3 zone setup with only one Lutron Maestro dimmer in the mix. I would like to have one additional zone on dimmer and be able to control them with a Beo 5 and one more Maestro switch may be the answer. I assume that the Beo 5 will not distinguish zones with three Maestro switches in the same wall gang.
If I could get the Beo5 to control each individual dimmer seperately that would eliminate the need for the grafik eye (3103) all together. I do not have a Beo5 yet, but it's on my wish list, as an option to the Lutron 3103 either way.
