Latest post 03-02-2010 11:35 AM by Chrisreunion. 1 replies.
Page 1 of 1 (2 items)
  • 03-02-2010 2:34 AM
    Beoport with Beocenter 2500 - Please suggest options
    Hi All:
    This is a great forum and I am getting familiar with B&O stuff as I read more on these forums.
    Issue:
    Got a beoport for about 100 dollars....Big Smile got it with out thinking through it. I have a Beosystem 2500 and Beosound 1.
    Not sure if I can use the beoport with them. Any Ideas to use my new beoport with my other B&O stuff will be greatly appreciated
    Is it possible to setup Clock or timer on Beosystem 2500 with beocenter 2500?
    Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
  • 03-02-2010 11:35 AM In reply to
    Re: Beoport with Beocenter 2500 - Please suggest options
    In theory, BeoPort won't work with a BeoSystem 2500.
    In practice, it can work, but with limitations.
    You need a BeoLink converter box type 1611 to connect both units, the BS2500 via Datalink, and the BeoPort box via Masterlink.
    You'll have to setup the audio system to option 0, and the BeoPort box to option 2 , and connect your Beolabs + infrared sensor to the BeoPort box (that will become your main audio system). If you have a video system, it won't work (sorry!).
    BeoSound 1 being a non-BeoLink system, you can only send the audio from BeoPort to the AUX input at the back but without any control on BS1.
    Reunion Island is greeting you!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
