Latest post 03-02-2010 7:49 AM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 03-01-2010 10:53 AM
    Beocenter 2200
    I have two sets of speakers attached, and only one in each case is live. When I switch the leads in the box the other speaker becomes live.
    Is there some simple fix for this ( like a balancing switch that I haven't found) or will it need servicing? Are parts likely to be available?
    Thanks for any advice.
    Bob Olson
  • 03-02-2010 7:49 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2200
    Welcome to Beoworld !
    There are a few things to check;
    Make sure that you have connected each pair of speakers to a left/right pair of connectors respectively.
    Speaker set 2 has a switch at the extreme lower front of the Beocenter (not all owners are aware of this).
    Check also that the balance control slider is centered.
    If all this is checked and the problem remains, it will have to be an electronic fault. Most likely a capacitor. There
    are a couple of tiny green radial ones on the board near the cutout for the dial gear. I've seen them fail many times.
    If the missing channel is related to the radio section only, with tape and phono working fine, the problem is usually
    in one of the MPX filters. They can go o/c for no apparent reason.
    Finally one of the amplifiers could be bad but that is a bit rare to see in this model.
