Latest post 03-01-2010 1:18 PM by Producer199. 2 replies.
Page 1 of 1 (3 items)
  • 02-28-2010 9:20 PM
    Beogram 1700 Running Slow
    My Beogram 1700 seems to be running a bit slow.
    Would this be a belt problem or is there any adjustments i could make?
  • 03-01-2010 2:38 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1700 Running Slow
    Welcome to Beoworld !
    It could be the belt but in most cases the symptoms of a worn belt is wow rather than a consistent slow speed.
    There are two holes in the black plastic bottom plate through which you can access adjustments for 33 and 45 respectively.
    You must use a 2mm flat-bladed "watchmakers type" screwdriver.
    If the speed cannot be set right, the adjustments can have gone bad and must be replaced (and readjusted), they
    are cheap components and a fairly easy job for your local repairshop if it should come to that.
  • 03-01-2010 1:18 PM In reply to
    Thanks Martin,
    I will give it a try.
    Gary
