Latest post 03-01-2010 3:30 AM by vikinger. 1 replies.
Page 1 of 1 (2 items)
  • 02-28-2010 5:10 PM
    Beocenter 1 PIN code
    How embarrassing.  Went away for the weekend leaving daughter in charge. For some reason she decided to switch off every socket she could find before going to bed..... resulting in the Beovisions demanding their PIN codes this morning. All sorted out except for the BC1 which has not accepted its code for some reason and is now going through a 3 hour WAIT for the third time. Can the PIN reset itself to a default when the power goes off? If I've actually got this PIN wrong is there any way of finding/ correcting it? (Phone call to dealer with serial number?)
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 03-01-2010 3:30 AM In reply to
    Re: Beocenter 1 PIN code
    Problem solved. Transposed two numbers............ Whistle
    Might disable the function now (as no-one would try to steal a CRT television weighing half a ton these days!) Or might write the codes down somewhere and not rely on my no longer infallible  memory!
    Graham
