Latest post 03-03-2010 5:55 AM by andy. 6 replies.
Page 1 of 1 (7 items)
  • 02-28-2010 4:11 AM
    • andy
    • Top 500 Contributor
    • Joined on 04-18-2007
    • weston-super(!)-mare
    • Posts 123
    Pentalab 2 Refurb
    Good Morning to all
    i have just bought some PentaLab 2 and of course foam rot has set in.....
    so, questions and/or advice...
    should i....
    replace drivers....
    refoam..........( best suppiler)
    replace/refoam only what needs doing.....
    do them myself ........( ham fisted and no patience...lol)
    do refoamed perform as well.....
    will replacement drivers last.....
    i have looked through various threads on refoaming, and while it looks a pain i am sure i can do it....but replacing the drivers looks easier but more expensive ( i am guessing the drivers are still available)
    regards
    andy
  • 02-28-2010 4:52 AM In reply to
    • Magnus
    • Not Ranked
    • Joined on 01-09-2010
    • Sweden
    • Posts 15
    • Gold Member
    Re: Pentalab 2 Refurb
    I had the same problem with my pentas and I refoamed them. The cost was less then 10% of what new drivers from B&O would cost.
    I bought the new foam rings from Good Hifi in Netherlands. They also have rubber rings but I went for original material (foam). http://www.goodhifi.com/  and then go to the webshop.
    It was quite easy to refoam the drivers, the trick is to find something to press down the ring to the cone and the frame while the glue is hardening. After some research in the kitchen area I found two mugs in different sizes. There is a refoam manual at Good Hifi's website.
    /Magnus
  • 02-28-2010 5:29 AM In reply to
    Talk to Brett when he calls next Sunday.
    Against my advice,  he has just refoamed a pair of Penta II and will be able to give you all the information!
    Personally, I have bought replacement drivers in the past and they are still available at around £25-£30 each.
    Regards Graham
  • 02-28-2010 1:31 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    hi andy
    have a go yerself - very satisfying - if not I'll be passing in about4 weeks on way to worcestershire could pick em up and do em for you!
    bc2 great well pleased
    salut
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 03-01-2010 7:37 AM In reply to
    • andy
    • Posts 123
    tony......thats not a bad idea.....if your sure ?
    andy
  • 03-01-2010 11:51 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    andy you have a pm!
    t
  • 03-03-2010 5:55 AM In reply to
    • andy
    • Posts 123
    tony..you have a pm.. !
