Hello Comrades
I have a lovely beolit 1000 radio with oak covers, in excellent condition......
The alloy (?) buttons however are quite tarnished and I appear unable to make much progress on cleaning them up. I have tried 'silvo', methylated spirits and 'metal polish' and nothing really brought them up to clean looking. The metal polish probably did the best job- under bright light they look clean, but then in normal light conditions they look quite tarnished again.
Any advice? Someone out there must have had a similar problem?
I even asked Lee.. but he has a perfect example of a beolit (as if he'd have anything else ). He did suggest a jewellery cleaning cloth, but thought I'd check with other beolit owners first. I gather the alloy buttons do tarnish over time?
Regards
David Coyne
BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
