Hi there fellow Beoworld-ers,
I just finished a restoration of a poorly 8000 - with parts and invaluable advice from resident B&O guru, Dillen.
The restoration has gone very smoothly and seemed a typical example of its type.
The trouble is, i have sat down to FINALLY hear the reward of my labours - and 1/2 an hour in - the thing just died. No sign of life - no blinking LED when plugging in the power - zilch. Pity, it was really sounding great
Luckily (maybe) i cant smell any "burnt" odours emanating from the unit. I just tried replacing the main 160mA fuse (seemed fine), but same result. All i can think is that as the PCB has heated up, one of the power supply solders has given way (i hope so anyway). Just hoping one of you may have an "aha" idea for me
Of course, i've posted off to Dillen (he must be a very busy man)- but i thought another 8000 owner may have an answer.
Cheers, Mike
