Yes, I suggest you try a direct grounding wire from chassis to chassis. Not all DIN/RCA
adapters pass both ground connections through.
Tonearm lowering faults like what you describe is very common and it takes a little explaining
of how the deck works to fully understand why it acts the way it does;
When you press play, the processor starts the whole deck up.
It orders the servo motor to drive the carriage towards the left.
When a certain amount of pulses from the shaft sensor has been counted, it
polls the tracking arm sensor to check for presence of a 12 inch record.
(If no 12 inch record is reported, the processor will allow the carriage
to continue to check for a 7 inch record, switch to 45 RPM etc.).
If a 12 inch record is sensed, it will slow down the carriage speed for the last
3-4 mm's until the tonearm is hovering over the lead-in groove.
All this is not timed but completely depending on pulses from the optical shaft sensor.
If the carriage is blocked or the belt is worn, the correct amount of pulses
may not be reached and the tonearm not allowed to be lowered automatically.
A slipping or too tight belt or a seized shaft/carriage/bushing will
not be able to transfer torque at the very low speed and/or the servo motor will not
have enough torque from the provided (low) voltage to move the carriage far enough
to reach the correct number of pulses.
Technically, your deck may be missing as little as a single pulse (less than 1/4 mm carriage movement,
not enough for most people to ever notice).
By activating the << button, you manually add the missing pulses by sending a higher voltage to the
servo motor and the deck will accept to lower the tonearm when you press play again.
Actually, after the correct amount of pulses has been counted, the system will
allow for the carriage to be backed out again enough to go just outside of a 12 inch
record and a manual lowering of the tonearm is possible.
This is useful when f.e. adjusting the tracking force dial.
