Should I be able to listen to the sound from my BS4 (audiomaster) in the computer room (from the speakers connected to Beoport), if the BS4 is connected via ML to Beoport and that to my Mac (USB + minijack)? I CAN listen to N.MUSIC in the main room and control the front row in the Mac with Beo4, and therefore the connections are ok. It seems impossible to get the sound from the BS4 to the Beoport, though. Is it impossible?
How about the same thing with linkplayer? Should I be able to use my Macs build-in speaskers EVEN when the sound goes out through minijack to the Beoport?
MANY thanks.
